Roomba Used To Map Indoor Air Quality
roomba_based_air_quality_tester
The next time you set off for a long day in the coal mines, forget the canary – bring your Roomba along instead!
While we are pretty sure that canaries are no longer used in the mining industry, this Roomba hack could make a suitable replacement if they were. A team from the Public Laboratory for Open Technology and Science (PLOTS) recently showed off a Roomba which they modified to test an area’s air quality. Using an Arduino and a volatile organic chemical (VOC) detecting air quality sensor, the Roomba goes about its normal business, lighting an LED any time it encounters overly contaminated air. When captured via a long exposure image, the process creates a “bad air” map of sorts, with the polluted areas highlighted by the glow of the LED.
While the Roomba currently only detects VOCs, the team plans on adding additional sensors in the near future to expand its functionality. The Roomba is merely a proof of concept at the moment, but we imagine that similar technology will be adapted for use in unmanned explorations of chemically hostile environments, if that hasn’t happened already.
[via DVice] [Image via TechnologyReview]
11 thoughts on “Roomba Used To Map Indoor Air Quality
  1. The “bad air” map is an interesting idea, but doesn’t the air move around and change the distribution? Wouldn’t even the Roomba itself passing by blow some of the gases around into a new pattern?
    I think I like the idea of driving it around an office and making some kind of a heat-map of the VOCs surrounding a particularly gassy co-worker’s cube, or something.
  2. Luke: I was thinking for use in indoor/underground confined spaces like utility tunnels, etc, where GPS wouldn’t work and people might not want to be using a sampling device at the end of their arm. Cuz, y’know, “Beep, beep, beep. Ohai, you’re kneeling in an area that exceeds the maximum permissible concentrations of $BADTHING, you should probably leave now.”
    cmholm: I prefer H2S, but to each their own. :)
Leave a Reply to RounderkattCancel reply
