Hackaday Links: July 24, 2011
Plasma speakers
Apparently if you run AC and DC currents through a welding torch flame you can use the resulting plasma as a loudspeaker. [Thanks Cody]
Power metering
The Google Power Meter API is no longer in development but that didn’t stop [Pyrofer] from finishing his metering hardware. It uses a reflectance sensor to read the meter instead of using clamp-based current sensing.
Music videos from inside the instrument
Filming from inside of a guitar creates the camera effect seen above which looks like the waveform you’d see on an oscilloscope. [Thanks Philleb]
Hidden messages in audio files
GhostCoder lets you encrypt and hide audio files within other audio files. The thought is, you can piggyback your own data into Torrents that are circling the interwebs.
2×4 Chair
If you’re skilled with a Skill saw you can make a chair out of one 2 by 4. You can see the pattern you’ll have to cut out from the board in the image above, wow!
15 thoughts on “Hackaday Links: July 24, 2011”
  1. Does anyone know about this ghostcoder software? How does it tamper with torrent files and not mess up the hash check? Wont people using the software just get marked as a bad uploader?
  2. We did the torch plasma speaker thing back in 1980 in physics lab. Read about it in some magazine and rigged something up to try it. Amazing how these ideas just keep getting dug up.
    The 2×4 chair is cool though.
  3. @haexn:
    It doesn’t tamper with torrent files, nor does it tamper with existing torrents. You have to make an entirely separate torrent with a file of your own. It’s a neat idea in theory, but it would only work if you were the first person to upload a particular song, and only if it was the highest quality upload. Not very useful in that respect.
  4. Oh hell yeah, that 2×4 chair looks great for $4. I’m always short a few chairs around here. And I bought like half a woodshop on the cheap a couple months ago… Time to put that bandsaw to good use I guess. :3c
    @loans: I’m guessing you didn’t download the PDF, huh?
  5. The power meter is awesome.
    Hey, here’s a photo of a PCB! With a PIC! USB too! It measures power usage, honest it does, see the graph!
    I guess the sensor wouldn’t fit in the frame. Great ‘hack’ indeed.
  6. Trying to be funny I see…. first off, it’s “Skil”, second, it’s a *brand* although most people associate it with a circular saw, which are cheap and ubiquitous. What you actually need is a band saw, a much more costly piece of equipment.
