R/C Blimp Uses A Party Balloon For Lift
Here’s a really tiny r/c blimp that doesn’t need several cubic feet of Helium to get off the ground.
Instructables user [masynmachien] has been building r/c blimps for over a decade now, and this latest build is meant to have the same specs as this nanoblimp. The build is based on an 11-inch party balloon that can provide about 11 grams of lift. This doesn’t allow for much leeway in terms of weight, so [masymachien] used hacked-up servos for the motors.
The blimp is an exercise in saving weight – just about every component that can be removed from the build is thrown away. The results are pretty impressive. The entire blimp weighs about 10 grams on the ground. [masynmachien] also tried a 14-inch balloon with an 808 key fob camera with very good results.
The blimp looks pretty good when flying around a room. [masymachien] seems to have a lot of control from a minimal component count. You can check out the party blimp in action after the break.
[youtube=http://www.youtube.com/watch?v=T5lKNE5S1dQ&w=470]
21 thoughts on “R/C Blimp Uses A Party Balloon For Lift
  1. I can’t wait until they figure out that the clown balloons work just as well and have the benefit of being easily formed into shapes both structural and artistic. Then we will see pink pigs flying round our heads with powered flight by wings of white.
      1. Clown balloons, at least small ones used to make balloondoggies, are made of much thicker latex than round party balloons. They won’t even float if filled with helium.
        There is one, however that is referred to as an airship. The dimensions of the airship in the brand I use to make large animals are 6 inches diameter and 46 inches long. It would make a formidable looking missile shaped blimp.
        Makes me want to take apart one of those little airhogs helicopters and hack something like this together.
Leave a Reply to Charles P. LambCancel reply
