Using Google Documents As A Web Proxy
As weird as it might sound, there’s a way to use Google documents as a web proxy. The image above is a screenshot of [Antonio] demonstrating how he can view text data from any site through the web giant’s cloud applications. Certain sites may be blocked from your location, but the big G can load whatever it wants. If all you need is the text, then so can you.
The hack takes advantage of the =IMPORTDATA() function of Google Spreadsheet. We guess the command is meant to make import of XML data possible, but hey, that’s pretty much what HTML data is too, right? But what good it the raw webpage code in a spreadsheet? This is where [Antonio] made a pretty brilliant leap in putting this one together. He authored a bookmarklet that provies a navigation interface, hides the raw code which is stored in the spreasheet, and renders it in the browser. This ties together a user supplied URL, reloading data on the hidden spreadsheet and refreshing the window as necessary. See for yourself in the clip after the break.
[youtube=http://www.youtube.com/watch?v=hQUTiXmdBUU&w=470]
12 thoughts on “Using Google Documents As A Web Proxy
  1. Of course, if Google Documents is also blocked (as it is where I work), this is not overly useful :) Still, a pretty good hack, IMHO.
  2. the first step is translate.google.com, choosing ‘original’ so it acts like a proxy.
    then embeding data in google docs. (images in their powerpoint for instance)
  3. This is awesome. We only have access to Google so this is a good work around. There is another limited way. Use Google to convert webpages to a mobile format. I’ve been doing this for months
  4. Why do this that complicated. Just acces Google Translate. There you can enter a webpage in the text field an than translate it to any language you want. Than you have in the right top corner the possibility to view the original page.
  5. can u make a proxy that dont alert school filters the school uses virtual computers that use ram to display everything,i always have to hack my ass through its anoying. it uses sophos wep protection.
Leave a Reply to ChalkBoredCancel reply
