Coffee Table Puts On A Show Behind Smoked Glass
This coffee table is a real show-piece. It’s got a smoky glass surface that is hiding the LCD screen within. But what fun would it be if it could only play video? The rest of the enclosure houses all the parts necessary to make this living room centerpiece into a computer.
After the break you can see a video showing off each step of the build process. It starts by ridding the screen of its enclosure, and using what’s left to determine the size of the wood frame for the table. With the display firmly in place [Nate] sets to work position, mounting, and developing cooling solutions for the motherboard and the rest of the bits. He does nice work and ends up with a table that we’d be proud to feature in our homes.
Now he’s got a lot of computing power and a huge display, but isn’t something missing? How hard do you think it would be to add touch sensitive input to this? We’re wondering if the overlays used to make those Android touchscreens could be mounted on the underside of the glass?
Build log photos:
[youtube=http://www.youtube.com/watch?v=bH4QiAsTPCw&w=470]
Short demo:
[youtube=http://www.youtube.com/watch?v=WhsNt4Sp97s&w=470]
[Thanks Mathew]
17 thoughts on “Coffee Table Puts On A Show Behind Smoked Glass
  1. rather than doing touch screen which seems very expensive at that size how about just suspending a camera above it since its a stationary table and using that for input or a kinect perhaps?
    1. Wouldn’t a touch screen on this render it useless as a table? I think a Piezo element for a knock sensor (as seen in the Web Interface Universal Remote Control two days ago) would add the right amount of interactivity for perhaps skipping tracks etc. without being overkill. (Note: Please adjust you definition of overkill when talking about giant screens in coffee tables)
  2. Mount it at an adjustable forty-five degree angle to the horizontal, with a pull out tray at the bottom for the keyboard and mouse/touch pad/graphics tablet.
    Voilá.
    Drafts board computer system.
  3. Adda mimio digital meeting assistant. Its a usb sensor bar that you put on your projection screen, use an electronic pen, and a projector to interact with a computer for “front of the class” work. You can find them on ebay under $100.
    You could easily place it in the bezel area and use its calibration to size the scan area of the screen. That way you can have the interaction similar to touch…but just when you are using the stylus….not when you set your coffee down.
  4. Unfortunately you couldn’t use the touchscreens from the Android build under the glass as they are resistive (require force to operate). If it were easy to build a capacitive touchscreen (think iPad) of this size, I’d build one in a heartbeat.
    1. Have you ever seen an Android phone? Only cheap Chinese rip-offs have resistive touch-screens, nearly every is capacitive.
  5. It’s quite possible to turn this into an LLP (laser light pane) if you want touchscreen input. I’d pair it with a really wide fisheye lens.
  6. Next time make the legs hollow (using yer uber wood skills) and allow the power to be routed through any of the four. It looks horrid underneath. This is not how you build a table…this is how you build a wooden oven for some computer stuff. Run an outlet box in the floor or something or snake the cables under that patio grade carpet and kiss away the deposit on yer apartment. If you’re on a cement slab it’s almost hopeless to have this look clean…I guess you don’t have cats or small children either. I apologize for the rant, but 3 short throw pico projectors, with laptop is best way to go…and having contacts in the legs for inductive charging. : )
    1. Yeah, it runs cool in there. But it was just something we tossed together with minium of tools and skills.
      Machine just sits in the corner now, don’t have a big enough lounge at the moment.
      Was just a fun project to prove that if u have an idea u can just attempt it.
      Nate
Leave a Reply to MojoCancel reply
