Some Technical Improvements On [Alton Brown’s] Hacked Smoker
Bringing that smoky goodness to your cooking is neither hard, nor is it expensive. [Alton Brown], who we consider to be the MacGyver of cooking, always seems to be able to build cooking contraptions from common items. The smoker he built from a flower pot was the inspiration for [Tom’s] own project. But [Tom] added in PID hardware to smoke at just the right temperature.
The enclosure hides a single electric burner at the bottom. A metal tray full of wood chips sits on top of it, smoldering as the burner gets hot. You could just set it and forget it, but it will take a lot of trial and error to figure out which setting achieves the best results. [Tom’s] additional hardware, housed in the grey electrical box, switches the burner with a solid state relay. The PID controller takes measurements from a temperature sensor inserted in the lid of the smoker, ensuring perfectly prepared food every time.
If you’re interested in making your own you could try building a heating element from toaster oven parts.
6 thoughts on “Some Technical Improvements On [Alton Brown’s] Hacked Smoker
  1. You can buy all sorts of complete heating elements and NiCr spirals from ebay, for very little money.
    No need to slaughter a toaster.
    I’m using one of those (called “Cartridge Heater Mold Heating Element”) as an igniter for my pellets oven.
Leave a Reply to Cyk Cancel reply
