[Maximilian Güntner] dropped us a comment in last week’s globe writeup linking to his own project, which involves a similar high power LED driver mod. This looks like the exact same mod we came up with, and [Güntner] even used the mod to connect a bunch of high power LEDs to a PCA9685 LED driver [pdf]. It’s the same exact concept as Disco Planet!
It should come as no surprise that people have actually been modding high power led drivers in this way for some time. They are a few bucks per handful and take an enormous input voltage range. In [Güntner]’s case he grabbed a bunch of these from Dealextreme. Actually there are two others on the site, and all three contain comments (dating back a year) with helpful tips on various ways to modify the little PCB.
Our Ebay sourced boards are different though. The boards [Güntner] purchased employ the PowTech PT4115 [pdf] which uses fewer parts and has an easy to follow data sheet. Take, for instance, the pin graciously labeled “DIM” with a little PWM signal next to it. The nerve! The Ebay drivers use the MCP34063 [pdf] which has a much more cryptic data sheet (burned two weeks and several notebook pages to figure out the circuit). Ultimately the two are so similar it makes no difference.
So, if you want to mod some LED drivers on your own, check out the how-to video after the jump. Thanks [mguentner]!
[youtube=http://www.youtube.com/watch?v=sohPA29wnFo&w=470]
Seems that the specs on the linked DX site ‘other two’ are messed up. Current and watts. These are made for track lighting with 12 volts AC as source, hence the diodes.
