Nintendo Light Gun Retrofit Lets It Play Color-based Games
This Nintendo light gun, aka Zapper, looks like a stock device. But a peek inside shows that the circuit board has been replaced. [CNLohr] added USB functionality and a few extra sensors that let him write his own games for that use the classic controller.
After cracking open the case he measured the shape of the circuit board so that he could recreate it exactly. This let him design his own board that would drop right into the same plastic support pieces as the original. His circuit uses an ATmega8u2 to provide a USB connection and read the attached sensors. One interesting aspect is the group of four long traces that act as an expandable i2c bus. [CNLohr] went with this so that he could use daughter boards to add in sensors later. In the demonstration seen after the video he’s using a photodiode as a color sensor. It allowed him to write the color-based game seen above where you shoot a different color of target in each round.
[via Reddit]
4 thoughts on “Nintendo Light Gun Retrofit Lets It Play Color-based Games
  1. Not bad.
    Now go recreate the best arcade shooting game ever made –
    https://www.google.co.uk/search?q=point+blank+arcade+game
    I think i prefer the way the WiiMote does it though, a pure IR marker pair tracking with an actual camera… Gives you actual hit coordinates. I’ve used a WiiMote for a couple of little experiments in tracking, and I’m continually blown away at how precise it is, even with it’s relatively low resolution IR camera.
  2. wii mote is 100% hampered by its forced ability to rely on a shoddy sensor.
    i’d like to see a full homebrew based color game released for this and for the boards to be made available for the end-user.
    1. I am going to be making more boards for another gun, but I am confused why you would want to avoid a wiimote for something like this?
Leave a Reply to StuCancel reply
