Halloween Props: Spooky Eyes Light Up The Bushes
This is just one example of several pairs of spooky eyes which light up [Vato Supreme’s] bushes this Halloween. The quick and inexpensive build process make it a perfect diy decoration.
Each eye is made up of a ping-pong ball and an LED. But that alone won’t be very spook as the entire ball will glow rather brightly. So he spiced things up a bit by masking off the shape of a pupil and spraying the balls black. The vertical slit seen in white above will glow red like a demon in the night.
The LEDs are driven by an ATtiny85 running the Arduino bootloader. [Vato] found there was plenty of space two write code which fades the eyes in and out using PWM. This happens at random intervals for each of the four pairs he is driving.
We’ve seen a similar project that used oversized LEDs as the eyes. But we really like the idea of using a diffuser like this one. See it in action after the break.
11 thoughts on “Halloween Props: Spooky Eyes Light Up The Bushes
  1. “… space two write code …”
    Come on HAD editors, now you’re just fucking with us. You can’t seriously be that inept in the writing skills department…
      1. …here for the hacks, yes.
        But jesus, have some standards. Proof-read, peer-review… /something/.
        Internet Rule #17: Read before you post.
  2. Oh yeah, If you own an Eggbot, detailed eyes would also be pretty easy. I think that the stock GE xmas lights look OK as is.
  3. The ATtiny85 is not running the Arduino Bootloader and cannot – ATtiny85 does not have hardware bootloader support and is incompatible with bootloaders which aren’t specifically designed for attiny chips.
    This project uses a full size arduino as an ISP programmer.
    1. Hmmm… You’d better let the Digispark guys know. Pretty sure they have an Arduino bootloader running on their ATtiny85 board.
Leave a Reply to wowme@wtf.comCancel reply
