Camera Gantry Rides On Garage Door Tracks
For as many garage and workshop videos we feature here on Hackaday, we’re surprised we haven’t seen this sooner.
[Todd] makes a bunch of videos in his garage shop, but using a tripod is a pain; he’s always tripping over his camera setup and it is just generally in the way all the time. His solution was to mount his camera to an overhead gantry, using the unused tracks for his garage door to move the camera around his workshop.
The build started with [Todd] taking his tripod and fabbing a mounting plate for it to be suspended in mid-air. This would leave the camera upside-down, so [Todd] also made a 90 degree bracket with a 1/4-20 bolt to hold the camera in position.
The actual gantry part of the build is fairly clever. First, [Todd] got a piece of square tubing the same length as the distance between his two garage door tracks. He made a truck that rides on six casters for this tube, then mounted this tube on garage door wheels.
The result allow [Todd] to move his camera anywhere within the footprint of his garage door tracks, including over his workbench and welding area. An ingeniously useful build that’s sure to provide a stable platform for his vlog-type thingies.
Vidia after the break.
4 thoughts on “Camera Gantry Rides On Garage Door Tracks
  1. I have been thinking of a similar project but admire that you actually did it in a timely fashion. It might have been nice to make it a little less heavy duty and less spot welds. Moreover watching your video was more constructive then most tv entertainment. Thank you.
Leave a Reply to William Cancel reply
