H-bot Style 3D Printer Moves Bed For Z-axis
Check out this 3D printer (translated) which [Arkadiusz Śpiewak] has been working on. When sending in the tip about his project he made the important distinction that it isn’t finished, but he has reached that critical threshold where he has printed items with it.
He decided to go with a design that is sometimes referred to as an H-bot. If you’re completely unfamiliar with it, you may find this H-bot design article helpful. The gist of it is that this technique makes it so that the motors used to move the extruder along the X and Y axes are themselves stationary. One large timing (toothed) belt makes a circuit around the top of this cube in the shape of the letter H. This is a bit easier to see in [Arkadiusz’s] rendered image found after the jump along with video of an early print test.
The Z axis uses two motors mounted along the bottom of the cube. These raise and lower the bead, instead of moving the extruder itself. All-in the printer should have a maximum object size of 30x30x30 centimeters. It’s being driven by a Smoothieboard, which was mentioned quite a bit when we were discussing using the RA driver board with a 3D printer.
hbot-zaxis
http://www.youtube.com/watch?v=edFl9tjkxFE
30 thoughts on “H-bot Style 3D Printer Moves Bed For Z-axis
    1. Yes, makerbot replicator, ultimaker, tauntillus are moving bed in Z axis. But on replicator you are also moving X motor. And on ultimaker and tauntillus x-y gantry cant take to much load, thats why they are using bowden extruder.
      On h-bot i get both, lght weight x-y gantry, but also enough strenght to have direct drivern extruder, or even dual one.
      Its just diffrent design, it has it good and bad sides.
    2. In addition to the consumer/hobbiest 3d printers, most commercial 3d printers move Z instead of everything else.
      The RepRap Mendel (and its many derivatives) uses a bed that is stationary on the Z axis to make it more compact.
    1. The wiki ( documentation ) itself is updated often, but we don’t use the blog much because it’s not very convenient to use. I’ll put some work into that, and start doing more frequent updates.
      The community really revolves around the IRC channel ( #smoothieware @ irc.freenode.net ), the website is just for documentation.
    1. In what way? Mass thats moving on this printer is very low comparet to prusa, on h-bot only x axis and extruders are moving with fast speed. All stepper motors are stationary besides extruder one. Misumi 20×20 profiles are also very rigit.
      Aslo i have ability to use big nema 23 motors, that are cheaper for same or greater torque, and im not addind any payload.
      1. Well, if the mass of the object being printed isn’t centered on the table’s horizontal axis it’ll cause a tilt. It’s a fairly big table on a fairly narrow support.
        1. So what weight were you thinking about? Most 3D printed stuff is around 10-20 grams and takes about half an hour (on an ultimaker) to print. That is never going to move with those (indeed massive overkill) linear slides.
  1. This H-belt-design looks really interesting. It seems you need less smooth rods for the x-y-axis than for exaple the Ultimaker and less bearings as well.
    Does it have a particular disadvantage?
    1. You need 6 idlers for belt placed in such way that belt is always parralel to smoothbars and itself, so all radiuses have to be exact. All those bends and lenght of belt byitself needs some force to move belt around, so you need more torque, thats why im using nema 23 1Nm motors.
      Other than that o dont se any big disadvantages, its just less comon used design so had some design problems on the way.
  2. I am working on a similar design for about 6 months now and i can tell you just by looking at your acceleration and speed(very low) in the vid that you have the common bed vibration/shaking problem associated with designing floating Z lift axis. Let us know if you find a solution to the problem other than software.
    1. I’ve used the rails that are on the Z here, they are extremely sturdy, I don’t expect any bed vibration/shaking.
      The low speed is indeed due to a problem we have in smoothie when combining high speeds and high step rates.
Leave a Reply to pCancel reply
