[Travis Goodspeed] Starts A Space Agency In Southern Appalachia
travis-goodspeed-space-tracker
His space agency hardware might be in Southern Appalachia, but he can control it from anywhere in the world. That’s right, [Travis Goodspeed] started his own space agency — well kinda. The first piece of hardware operated by the organization is this dish for tracking moving targets in near space.
The main part of the build is a Felcom 82B dish which  was designed to be a satellite link for naval vessels. The image showing the back side of it exposes all of the extras he built into the system. Don’t worry though, a dome goes over the top to keep the weather out without encumbering its operation.He uses an SDR dongle to handle the radio communications. That connects to a BeagleBone which pipes the data to his handheld over the Internet.
It’s amazing to see this type of hobby project. It wasn’t that long ago that you needed an entire room of hardware to communicate with satellites.
14 thoughts on “[Travis Goodspeed] Starts A Space Agency In Southern Appalachia
  1. In the early 90s you could use a RF modem+dish+200Mhz pentium laptop and uplink to any AX.25 satcom out there.. It’s not hard to do, it’s the scheduling and licensing that makes it useless, given most of them only allow relays to amateurs..
    I’m interested in what speed this can track and what software he uses. I’ve seen how how sensor meshes are used with hydraulic drives on military tracking systems, even they can’t track most things.
  2. Naval vessels? I think you mean shipping vessels, or merchant shipping vessels. It’s not just warships that require satcomms, and there’s a darnsight more shipping on the sea than warships.
Leave a Reply to Xsjado Cancel reply
