RFID Door Access Robot
RFID Door orbot
We love hackerspaces. Some of the most innovative solutions come from them thanks to having like-minded people all hanging out in the same place. Just take a look at this awesome RFID door system from the Lansing Makers Network that doesn’t require any modification of the door.
The majority of the mechanism was previously a model draw bridge that the space purchased from a surplus store — it just needed a bit of hacking. Almost all members of the space had some part in the project, whenever the build hit a snag, another member always had the right solution. It works by using a windshield motor that tightens a seatbelt around the push-bar latch of the door — the beauty of the system is it is completely non-damaging to the door, and the door works exactly the same as before. The whole system is controlled by RFID tags, which the members have as keys to the space.
It’s an awesome project and [Brian] has written a really great write-up on it, which also happens to segue nicely into the topic of hackerspaces. He describes hackerspaces as
the Wikipedia of real life, and everything else here [tools, equipment, resources] is just the lure that pulls us all together.
Stick around after the break to see the mechanism in action!
http://www.youtube.com/watch?v=blJulmDmmYE
6 thoughts on “RFID Door Access Robot
  1. And their website wilts at the first hint of traffic. How can something hosted on a MI State Uni network die so fast? Maybe the Arduino that controls their front door also hosts their website?
  2. Should be back up and running now. The logs suggest that traffic didn’t have anything to do with the downtime – the timing was just an unfortunate coincidence. Back to complaining about Arduino, nothing to see here! :)
    1. We did consider that. In the end it came down to wanting to make sure anything we put on the crash bar, if pushed, would let the door open (or at least wouldn’t make you think in some sort of haste that it needed to be removed to make the door open).
      Plus, we had a car window motor (plenty of torque to get the job done) and didn’t have any servos with enough power to push the bar. :-)
Leave a Reply to EirinnCancel reply
