X-Wing Tri-Rotor Brings Star Wars To Life
xwing
Once you realize you can make almost anything fly if you strap a big enough prop and motor to it, you really start thinking outside of the box. That’s what [Rodger] did and he’s come up with this very impressive 19lb, 5′ long X-Wing Fighter from Star Wars.
Recently [Rodger] has found new joy in making movie props come to life with the help of today’s technology. He started with Project Thunderball — a flying James Bond mannequin with a jet pack. From there he brought us the Marty McFly working hover-board, and now an X-Wing Fighter, his biggest flying machine yet.
It measures about 5 feet long, and is a tri-rotor design with three 100A ESCs, 1200W 1050KV motors, and 12″ rotors. The frame is made of PVC to conserve weight. Since it’s a tri-rotor with true vectored thrust, the X-Wing features much better yaw than quadrotors. Then only problem is it pivots around the odd prop out, meaning in this case, the X-Wing turns on its nose — instead of its tail.
Regardless, we can’t wait to see what [Rodger] tries flying next! Stick around to see the X-Wing in action.
25 thoughts on “X-Wing Tri-Rotor Brings Star Wars To Life
  1. Pretty cool!
    1050KV motors?! 1.05 Million Volts? We don’t have enough gigajoules for that! :-)
    (yes I know it’s a model)
    Also the description says 850W motors, not 1200W.
    Did he redirect his website to youtube to avoid the HaD effect?
  2. Almost sounds like a landspeeder with the rotor whine. Tool cool for sure, I would be fun to see the frame filled in with some lightweight sheet material so I could blur my eyes and imagine my original SW toys taking flight. Where does this guy find the time (jealous)?
Leave a Reply to Mike CCancel reply
