An old Neo Geo Arcade, a Raspberry Pi, and some time were all [Matthew] needed to build this Pi Powered Arcade Emulator Cabinet.
Neo Geo was originally marketed by SNK as a very expensive home video console system. Much like the Nintendo Play Choice 10, SNK also marketed an arcade system, the MVS. The Neo Geo MVS allowed arcade operators to run up to six titles in a single cabinet. The MVS also allowed players to save games on memory cards.
[Matthew’s] cabinet had seen better days. Most of the electronics were gone, the CRT monitor was dead, and the power supply was blown. Aside from a bit of wear, the cabinet frame was solid and the controls were in good shape. He decided it would be a good candidate for an emulator conversion.
We’ve seen some pretty awesome arcade conversions in the past, such as this Halloween rendition of Splatterhouse. For his conversion, [Matthew] stuck to the electronics, leaving most of the old arcade patina intact. The CRT did fire up after some components were replaced. [Matthew] ran into some refresh rate issues with the Raspberry Pi, so he opted to swap it out with a modern LCD monitor. Controls were wired up with the help of an I-PAC board.
[Matthew] had to write a driver to handle the I-PAC, but he says it was a good learning experience. Aside from the LCD screen, the result looks like it could be found in the back of an old bowling alley, or a smokey bar next to Golden Tee. Nice work, [Matthew]!
