What do you get when you combine one of the best (and certainly one of the best for the price) software defined radios with the user interface of a 10-year-old iPod? The HackRF PortaPack, developed by [Jared Boone], and demonstrated at DEFCON last weekend.
[Jared] is one of the original developers for the HackRF, a 10MHz to 6GHz software defined radio that can also transmit in half duplex. Since the development of the HackRF has (somewhat) wrapped up, [Jared] has been working on the PortaPack, an add-on for the HackRF that turns it into a portable, ARM Cortex M4-powered software defined radio. No, it’s not as powerful as a full computer running GNU Radio, but it does have the capability to listen in on a surprising amount of radio signals.
Because [Jared] is using a fairly low-power micro for the PortaPack, there’s a lot of tricks he’s using to get everything running smoothly. He gave a lightning talk at the Wireless Village at DEFCON going over the strengths and weaknesses of the chip he’s using, and surprisingly he’s using very little floating point arithmetic in his code. You can check out the video for that talk below.
Just after filming this interview Jared showed how the hardware can be used to listen in on our wireless microphone. Took about 2 minutes to set that up.
…which means you can also listen to static at a RepRap convention, or music at a retro computer con.
Shout out to PDX!!
Great build too Jared :-D
Nice! I assume he’s dedicated the M4 core to SDR work and is using the M0 for the UI and house keeping?
It has no core on board, it is using the HackRF CPU and co processors and updating the port-a-pack screen via GPIO. As far as I know.
Am i the only one who immediately thought about a backpack portapotty when reading “PortaPack”?
So cool…Probably going to get a HackRF after making an SDR w/ BBB. Need to learn how to do signal processing code, last I looked it was HARD…
There is no such thing as hard or complex, it is just loads of little simple things. Put enough of them together and it looks really scary.
True it gets easier after studying for a while…Just don’t want false signals/data.
SFR from 10Mhz to 6 GHZ? Wow. The improvement in SDR tech is pretty mind-boggling.
DorkbotPDX represent!
