Home Made CNC Router Boasts Welded Steel Frame And Super Tidy Wire Management
Tweakie CNC Router
[Cooperman] had been poking around the ‘net checking out DIY CNC machines for a while. He wanted to build one. During his search, he noticed that there was a common thread amongst homemade machines; they were usually made from parts that were on hand or easily obtainable. He had some parts kicking around and decided to hop on the band wagon and build a CNC Router. What sets [Cooperman]’s project apart from the rest is that he apparently had some really nice components available in his parts bin. The machine is nicknamed ‘Tweakie‘ because it will never really be finished, there’s always something to tweak to make it better.
The foundation for Tweakie is a welded frame made from 25mm steel square tubing. A keen observer may point out that welding a frame may cause some distortion and warping. [Cooperman] thought of that too so he attached aluminum spacers to the steel frame and lapped them flat. After that, fully supported THK linear bearings were attached to the now-straight spacer surface. Both the X and Y axes have ball-screws to minimize backlash and are powered by NEMA23 stepper motors. The Z axis uses 16mm un-supported rods with pillow block linear bearings. Unlike the X and Y, the Z axis uses a trapezoidal lead screw and bronze nut. [Cooperman] plans on replacing this with a ball-screw in the future but didn’t have one on hand at the time of assembly.
Mach3 is the software being used to control the CNC Router. It communicates via parallel port with a 3-axis StepMaster motor driver board that can handle providing 24vdc to the stepper motors. All of the electronics are mounted neatly in an electrical cabinet mounted on the back of the machine. Overall, this is a super sturdy and accurate machine build. [Cooperman] has successfully cut wood, plastic and even aluminum!
15 thoughts on “Home Made CNC Router Boasts Welded Steel Frame And Super Tidy Wire Management
  1. Yippie! You fixed the broken link. I was looking for a general “report a problem” button but couldn’t find one. Maybe HackaDay could add one?
    As for Tweakie, looks nice and beefy. Any results yet?
    Am I the only one who doesn’t have linear bearings and ball screws lying around?
  2. It’s worth pawing through the rest of the site to understand both his pile of quality parts and skill at assembly – rebuilding APUs for fun and making carbon-fiber R/C boats for sport. A good source for tweaks and tips on things like bit design for different materials and how to pull it all together, not to mention quality standards to aspire to.
  3. Cooperman is a gentleman suffering (or enjoying) a glorious case of OCD. If Tweakie truly came from his parts bin then I would love to sort through what he throws away.
    His website is well worth the time and while not glitzy is relatively clean and packed with information. It is well worth spending some time there.
    Some parts of Tweakie need…tweaking, but my favorite part is that glorious red button located in easy reach.
    Well done!
Leave a Reply to GalaneCancel reply
