Get Biohacking With A DIY CO2 Incubator
The [Pelling Lab] have been iterating over their DIY CO2 incubator for a while now, and it looks like there’s a new version in the works.
incubator3
We’ve covered open source Biolab equipment before including incubators but not a CO2 incubator. Incubators allow you to control the temperature and atmosphere in a chamber. The incubator built by the [Pelling Lab] regulates the chambers temperature and CO2 levels allowing them to culture cells under optimal conditions.
While commercial incubators can cost thousands of dollars the [Pelling Lab] used a Styrofoam box, space blanket, and SodaStream tank among other low cost parts. The most expensive component was a CO2 sensor which cost $230. The rig uses an Arduino for feedback and control. With a total BOM cost of $350 their solution is cost effective, and provides an open platform for further development.
The original write up is full of useful information, but recent tweets suggest a new and improved version is on the way and we look forward to hearing more about this exciting DIYBio project!
6 thoughts on “Get Biohacking With A DIY CO2 Incubator
    1. The cheap ones are only able to measure up to 1% of co2 concentration and this project needs to measure around 5%
  1. Also, keep in mind the AU to US dollar exchange rate is about $0.75. Agree with previous poster. I’ve looked into this myself and found the same issue with the cheaper sensors not having the proper range.
  2. Is there an a PDF of the instructions to make a DIY CO2 incubator? The link is broken, likely because they went commercial. Thanks!
Leave a Reply to bkdaddy79Cancel reply
