Broken Finger Is No Obstacle To Modern Hacker
[Jim Merullo] and his son were enjoying a nice game of Frisbee when an unfortunate dive led to an injury. His son broke his pinky finger leaving doctors no choice other than bounding his entire left hand in an unreasonably large cast. For most, this would mean no use of the left hand for several weeks, which is somewhat problematic if tin01your son has a Minecraft addiction.  [Jim], however, is no stranger to the hacker community and began working on a solution. He broke out the #2 Philips screwdriver, fired up the soldering iron and got to work.
A detailed analysis of the injured left hand revealed limited use of the middle and ring finger, and full use of the thumb. Because his son played the game using his right hand for the mouse and left for the keyboard, he needed to find a way for him to operate a keyboard with the limited use of his left hand. He took apart an old USB keyboard and soldered up some tactile switches to emulate the needed key presses. After making a fashionable Altoids tin mount that fit over the cast, his son was able to enjoy his favorite video game with limited interruption.
18 thoughts on “Broken Finger Is No Obstacle To Modern Hacker
    1. Joke doesn’t work, there’s no misplaced comma to allow for an alternate reading like that.
      yes I posted to point that out :P
  1. This is why you do not play outside, if he would have stuck with Minecraft this would not have happened.
    (Joking by the way, breaks are good (no pun intended))
  2. … That ain’t the kinda cast you get for a just broken pinky. And both the 4th digit and the pinky can move, so it is not being effective at stabilising the pinky.
    A Second opinion, or at least a recast at the next check may be in order.
    (But thankfully pinky fingers heal pretty well, even if just taped to the ring finger. But if this is a more complex break like a salter-Harris or a metacarpal that degree of movement may be inadequate)
  3. This is stupid! The cast helps to stabilize the whole wrist and pinky, minimalizing stress on the fracture. That hand should rest as much as possible to ensure proper healing. Moving the other fingers will put stress on that fracture via muscles, tendons, etc.
Leave a Reply to ChrisCancel reply
