Low Background Steel — So Hot Right Now
The nuclear age changed steel, and for decades we had to pay the price for it. The first tests of the atomic bomb were a milestone in many ways, and have left a mark in history and in the surface of the Earth. The level of background radiation in the air increased, and this had an effect on the production of steel, so that steel produced since 1945 has had elevated levels of radioactivity. This can be a problem for sensitive instruments, so there was a demand for steel called low background steel, which was made before the trinity tests.
The Bessemer process pumps air through the iron to remove impurities. shropshirehistory.com
The production of steel is done with the Bessemer process, which takes the molten pig iron and blasts air through it. By pumping air through the steel, the oxygen reacts with impurities and oxidizes, and the impurities are drawn out either as gas or slag, which is then skimmed off. The problem is that the atmospheric air has radioactive impurities of its own, which are deposited into the steel, yielding a slightly radioactive material. Since the late 1960s steel production uses a slightly modified technique called the BOS, or Basic Oxygen Steelmaking, in which pure oxygen is pumped through the iron. This is better, but radioactive material can still slip through. In particular, we’re interested in cobalt, which dissolves very easily in steel, so it isn’t as affected by the Bessemer or BOS methods. Sometimes cobalt is intentionally added to steel, though not the radioactive isotope, and only for very specialized purposes.
Recycling is another reason that modern steel stays radioactive. We’ve been great about recycling steel, but the downside is that some of those impurities stick around.
Why Do We Need Low Background Steel?
Imagine you have a sensor that needs to be extremely sensitive to low levels of radiation. This could be Geiger counters, medical devices, or vehicles destined for space exploration. If they have a container that is slightly radioactive it creates an unacceptable noise floor. That’s where Low Background Steel comes in.
A person is placed into a low background steel container with sensitive equipment to measure the radioactivity of the body, which may be near the background level. Photo from orau.org
So where do you get steel, which is a man-made material, that was made before 1945? Primarily from the ocean, in sunken ships from WWII. They weren’t exposed to the atomic age air when they were made, and haven’t been recycled and mixed with newer radioactive steel. We literally cut the ships apart underwater, scrape off the barnacles, and reuse the steel.
Fortunately, this is a problem that’s going away on its own, so the headline is really only appropriate as a great reference to a popular movie. After 1975, testing moved underground, reducing, but not eliminating, the amount of radiation pumped into the air. Since various treaties ending the testing of nuclear weapons, and thanks to the short half-life of some of the radioactive isotopes, the background radiation in the air has been decreasing. Cobalt-60 has a half-life of 5.26 years, which means that steel is getting less and less radioactive on its own (Cobalt-60 from 1945 would now be at .008% of original levels). The newer BOS technique exposes the steel to fewer impurities from the air, too. Eventually the need for special low background steel will be just a memory.
Oddly enough, steel isn’t the only thing that we’ve dragged from the bottom of the ocean. Ancient Roman lead has also had a part in modern sensing.
82 thoughts on “Low Background Steel — So Hot Right Now
    1. They’ll be thinking “Sure are a lot of extremely generous grants around for locating and characterizing shallow water wrecks right now. Life is good. Maybe I’ll put that deposit down on that BMW.”
        1. it is so far from a one or the other scenario that the above comment is so far beyond wrong it aint even funny, especially when looking at the world and not a single, insignificant country.
      1. Dude I think Archeology is working the dumps now too. I would imagine discovering those dumped Atari cartridges were actually Archeology and the dump areas were digs.
    2. One of the first things archeology students learn is that archeology is a destructive science. They will dig until they reach “geography” and then everything that once was there will be gone and transfered to paper.
  1. Radioactive elements get into steel from the coal that is used for the coke that is used to reducing iron oxide ores into pure iron. The coal deposits are full of uranium and thorium, along with their daughter isotopes which are concentrated in the resulting coal ash.
    That includes also the so-called man-made isotopes such as Cobalt-60. It is generally said that these isotopes don’t exist in nature, but they are generated in trace quantities due to the breakdown chains of uranium and thorium, so some amount is always present in rocks and soil.
    1. Iron oxide(s) are mined so blast furnace steel would not have the radioactivity problems of recycled steel. Why spend money dredging up old sunken armour when abundant iron oxides make up almost 10% of the earths crust.
    2. That makes sense but I remember hearing pretty much this same story more than 10 years ago. Either someone is keeping a scam going a very long time or the naturally present radioactive isotopes just aren’t significant enough to cause a problem while the unnatural ones are.
      As for the coal deposits… I would imagine not all coal deposits are equal right? Maybe they purposefully choose especially pure coal for making medical grade steel? Does anybody know anything about this?
  2. at some point the lead roofing on old churches and ballast from old wrecks were in high demand for BGA balls because the slight radioactivity of new lead could make bits flip in ICs
    1. Low-background lead is needed for extremely sensitive underground physics experiments. For the really, really low-background stuff (double beta decay, dark matter searches, etc) they want lead from relatively deep wrecks, which they move quickly to the underground sites in order to prevent activation from cosmic rays. Heck, they even store the detector materials themselves down-hole to let the activation products decay.
  3. Why not use air filters? they absolutely could create low background steel today, they just find it cheaper to hire divers than it is to actually update modern foundries from the 1920’s tech to modern day tech.
    1. Probably. When I worked at the Defense Nuclear Weapons School, we were surveying our radioactive training sites. I walked off site out of curiosity and found a natural rock that exceeded the NRC limit of 2 mRem / hr. This was near Albuquerque. I still have the rock. When I assayed it, it showed Uranium ore. Our training sites were seeded with natural Thorium.
  4. Underwater ships from WWII are also the graves of the sailors that lost their lives when the ship was sank.
    Demand for this low emissivity steel is causing underwater graves to be desecrated.
    1. I don’t think the dead care. What about the ones who were turned into a red mist and greasy smoke? Or burned up at 20,000 feet? Or recycling the hulks of burned out tanks?
    2. I never really understood the grave desecration argument.
      My rational side says a dead body is not a person. The person who it once was has no cares and doesn’t know what happens anyway. Decisions should always be made to favor the living.
      My irrational side imagines being a shipwreck victim myself. The thought of being trapped miles underwater sounds scary. I would rather my body brought back up. Do what you will with the broken metal can you find it in. Of course… I am not a sailor. Maybe their love of the sea makes it the perfect place for them to stay.
      People do like pretty cemeteries though. Shipwrecks don’t look like that. They look more like illegal side of the road garbage dump sites. If the bodies remain behind then maybe cleaning up the trash is a respectful thing to do.
  5. Most of the Low Background steel in use has come from the armour of the German High Seas Fleet scuttled at the end of WW1. There were now bodies in these ships, and most of them were salvaged in the 1920s and 30s. It’s a fascinating story. Here are a couple of interesting links. Some of the techniques Cox developed are definitely hacks! I read a book about Ernest Cox and the Scapa Flow salvage back in the 70s when one of my hobbies was naval history.
    http://www.scapaflowwrecks.com/history/salvage.php
    The Man Who Bought A Navy: The Story of The World’s Greatest Salvage Achievement at Scapa Flow – https://en.wikipedia.org/wiki/Ernest_Cox
    As this steel runs out the market has caused a new sort of piracy. Particularly around the sites naval battles in WW2, ships are being plundered without permission and in secrecy. Recent surveys have found ships either partially or completely removed from their known locations on the sea bed.
    http://www.livescience.com/56965-wwii-shipwrecks-vanish-after-illegal-plundering.html
    http://www.telegraph.co.uk/news/2016/11/16/dutch-probe-mystery-of-wartime-shipwrecks-that-appear-to-have-go/
      1. In the notes section of the book “E = mc2 A biography of the world’s most famous equation” (i highly recommend reading this book), the author David Bodainis mentions the salvaging effort of the german fleet in Scapa Flow. But the most interesting claim is, that parts of these ships made all the way to the moon as parts of the Apollo spacecrafts.
        David Bodanis references the book “The Grand Scuttle: The Sinking of the German Fleet at Scapa Flow in 1919” as the source of this claim, but i couldn’t find a copy to verify it.
    1. @Sadiq Mohamed
      So we filled the atmosphere with so much atomic murderdust it impedes construction of unimaginably sensitive scientific instruments. This turns artifacts from the most destructive war in human history into a valuable commodity, to the point where people–not nationstates, not huge mega-corporations, but groups of regular folks–are stealing warships off the goddamn *seabed.*
      This is the most postmodern things I’ve seen since my friend made $90 trading imaginary hats.
  6. “so the headline is really only appropriate as a great reference to a popular movie.”
    When I clicked on the link “popular movie” I was directed to zoolander (2001)… could somebody explain what this has to do with the article?!?!
    1. Ok
      Zoolander has Jon Voight who was in Uprising.
      Uprising had Donald Southerland who was in Kelley’s Heroes.
      Kelley’s Heroe’s had Gavin MacLeod who was in The Love Boat.
      The Love Boat had Dana Wynter who was in SINK THE BISMARK!
      The Bismark was made with WW2 German Steel.
  7. Just a minor point: the Bessemer Process is obsolete and hasn’t been used in the United States since 1968. Primary steel, made from raw materials, is now made in basic oxygen furnaces, which are similar in concept to the Bessemer Converter but use pure oxygen instead of air and allow better control of the steel chemistry. Electric arc furnaces are used to make secondary steel, steel made by mixing scrap metals to get the right chemistry. I don’t doubt the need for low-background steel, but I wonder if primary steel made in modern BOP furnaces absorbs as much radioactivity as Bessemer steel.
    1. Hmm.. what a great question. I can’t imagine where one would find the answer. Where oh where would I look? I guess I could try reading the article.
      ” Since the late 1960s steel production uses a slightly modified technique called the BOS, or Basic Oxygen Steelmaking, in which pure oxygen is pumped through the iron. This is better, but radioactive material can still slip through.”
    1. On a related (and somewhat political) note, the whole “bring our troops back from Japan and let them have their own army with nukes” idea might have worked well BEFORE North Korea had nuclear weapons.
      1. Generic Human
        Why?
        North Korea invading Japan is like the last Red Dawn remake.
        No point in nuking the Japs either.
        Just sabre rattling to keep everyone distracted.
        China holds the NK leash and oh so many resource goodies flow out of there.
        Besides there is a reunification movement on both sides. Both sides have family on the other. Asians are VERY family oriented.
        1. How would reunification work?
          Would the South Koreans actually choose to put themselves under Kim family rule?
          Or would our favorite North Korean dictator just give up all his power voluntarily?
          How does either one make any sense?
      2. NK doesn’t have enough missiles, subs, or planes for the full nuclear triad. Even if they did they don’t have enough warheads for a full MAD second strike. Even if they did they don’t have enough land for all the silos it would take. They do not, in fact, have a credible nuclear deterrent.
        As it is, they’re equipped to fuck up South Korea OR Japan, after which they would be completely flattened. They know that the moment they launch they would be on the receiving end of a multi-axis hatefuck that would make Grave of the Fireflies seem like Miracle on 34th Street.
        Even under the leadership of an unstable psychopath with bad hair they’re not going to nuke anybody because that order would have to go through a significant number of people deeply invested in the status quo, at least a few of which are statistically likely to be sane. We are not talking about a country with an entrenched and fortified quick-launch system built up through decades of nuclear development and doctrine.
        1. Blue Footed Booby
          “Unstable Psychopath”? Obama/Bush the lesser/Clinton killed more people that any Kim has.
          Individually at that.
          I see a small buffer nation surrounded by enemies rattling sabres at the Chinese behest. China looks Liberal, NK looks scary, the US and EU have a boogie man to terrify the kiddies with.
          Win win for everyone.
          https://en.wikipedia.org/wiki/North_Korea
          “North Korea’s policy is to seek reunification without what it sees as outside interference, through a federal structure retaining each side’s leadership and systems. In 2000, both North and South Korea signed the June 15th North–South Joint Declaration in which both sides made promises to seek out a peaceful reunification.”
          “The economy is heavily nationalized.[262] Food and housing are extensively subsidized by the state; education and healthcare are free;[263] and the payment of taxes was officially abolished in 1974.[264] A variety of goods are available in department stores and supermarkets in Pyongyang,[265] though most of the population relies on small-scale jangmadang markets.[266][267] In 2009, the government attempted to stem the expanding free market by banning jangmadang and the use of foreign currency,[254] heavily devaluing the won and restricting the convertibility of savings in the old currency,[203] but the resulting inflation spike and rare public protests caused a reversal of these policies.[268] Private trade is dominated by women because most men are required to be present at their workplace, even though many state-owned enterprises are non-operational.[269]
          Industry and services employ 65%[270] of North Korea’s 12.6 million labor force.[271] Major industries include machine building, military equipment, chemicals, mining, metallurgy, textiles, food processing and tourism.[272] Iron ore and coal production are among the few sectors where North Korea performs significantly better than its southern neighbor – it produces about 10 times larger amounts of each resource.[273] The agricultural sector was shattered by the natural disasters of the 1990s.[274] Its 3,500 cooperatives and state farms[275] were among the most productive and successful in the world around 1980[276] but now experience chronic fertilizer and equipment shortages. Rice, corn, soybeans and potatoes are some of the primary crops.[254] A significant contribution to the food supply comes from commercial fishing and aquaculture.[254] Tourism has been a growing sector for the past decade.[277] North Korea aims to increase the number of foreign visitors from 200,000 to one million by 2016 through projects like the Masikryong Ski Resort.[278]
          Foreign trade surpassed pre-crisis levels in 2005 and continues to expand.[279] North Korea has a number of special economic zones (SEZs) and Special Administrative Regions where foreign companies can operate with tax and tariff incentives while North Korean establishments gain access to improved technology.[280] Initially four such zones existed, but they yielded little overall success.[281] The SEZ system was overhauled in 2013 when 14 new zones were opened and the Rason Special Economic Zone was reformed as a joint Chinese-North Korean project.[282] The Kaesong Industrial Region is a special economic zone where more than 100 South Korean companies employ some 52,000 North Korean workers.[283] Outside inter-Korean trade, more than 89% of external trade is conducted with China. Russia is the second-largest foreign partner with $100 million worth of imports and exports for the same year.[284] In 2014, Russia wrote off 90% of North Korea’s debt and the two countries agreed to conduct all transactions in rubles.[285][286] Overall, external trade in 2013 reached a total of $7.3 billion (the highest amount since 1990[284]), while inter-Korean trade dropped to an eight-year low of $1.1 billion.[287]”
          http://thediplomat.com/2014/01/north-korea-may-have-two-thirds-of-worlds-rare-earths/
          North Korea May Have Two-Thirds of World’s Rare Earths
          A new estimate suggests that North Korea may have more than 6 times the amount of rare earths as China
          https://www.reference.com/geography/north-korea-s-natural-resources-f8f2a48048ff5c27
          North Korea is more successful when it comes to mineral resources. North Korea is speculated to be endowed with over six trillion dollars worth of rare metal resources. North Korea is a reservoir that is vast and mostly untouched due to North Korea’s extremely rigid and isolationist policies that prevent any foreign mining company from coming in and making use of the metal deposits beneath the soil. North Korea possesses very large deposits of iron and zinc, being the world’s eighteenth largest producer of both. The nation also possesses the twenty-second largest coal reserve in the world.
        2. “As it is, they’re equipped to fuck up South Korea OR Japan, after which they would be completely flattened.”
          Agreed but… If all that came to pass… how would China react?
    2. Dude Fukushima should scare the living crap out of everyone. It isn’t contained, every news article mentions ever increasing radiation and it dumps millions of gallons of radioactive water in the Pacific daily.
      That and Radiation detectors were turned off
      Thousands of times worse than Chernobyl.
  8. Though there would be some cost involved you could acquire oxygen for making new steel from electrolysis of water sources which are not contaminated(deep sea, glacial ice, natural aquifers).
    1. If you’re serious, you want to look up where the market for that is. Certainly some people are willing to pay a lot. I’d guess there are brokers who locate it, store it, and sell it to the few scientists who need it. Find yourself a specialty scrap metals broker?
  9. The radioactivity has increased because, you know, nuclear weapon USE. Is incredible? Is not. In Serbia (Yugoslavia) NATO has used depleted uranium projectiles – just one example. Perhaps, is better to have a Geiger counter when you visit other countries, mostly present/past war zone. Ussualy paranoia don’t kill peoples.
          1. Yeah but natural uranium tends not to occur around where people live, in any great quantity. People naturally get very little exposure to it. Especially in powder form.
      1. There is some evidence that even used Plutonium was used in some warheads. Rates of cancer in Serbia have doubled since NATO invasion in 1999. Even some occupying NATO troops were affected (Italians, etc.).
Leave a Reply to Sadiq Mohamed (@sid1950) Cancel reply
