[Joey Campbell] is studying for his PhD at the Bristol Interaction and Graphics Lab, focusing on the interplay between real and virtual objects within the realm of exergaming–“gamercising” where physical motion and effort drives the game. The goal is to make the physical effort seem to correspond with what’s seen on the headset.
[Joey] set up a test rig where an exercise bike’s gears were adjusted based on the terrain encountered, seeking to find out if that realism inspired a greater feeling of immersion. He also provided some test subjects a HUD with their heart rate and other stats, to see if that encouraged gamers to exercise more.
In his current project, [Joey] has equipped a wheelchair with a pair of Arduino-controlled servos that squeeze the brakes to simulate an obstacle. In the VR realm, a player pushes the wheelchair toward a virtual block and the brakes engage, requiring the player push harder to bypass the obstacle.
One imagines the possibilities of games designed for specifically for wheelchairs. The Eyedrivomatic wheelchair that won the 2015 Hackaday Prize sounds perfect for the job!
Tie it in with Google Maps so they can exer-whatever with existing bike trails and scenery.
I’ve already seen some Maps-connected bikes you can use to go anywhere…
Zwift
Finally we’ll have realistic VR Doom!
Imagine kicking down virtual doors!
And maybe VR Portal, with the ability to go from test chambers to real life and vice versa through portals.
This looks promising: http://hackaday.com/2017/05/14/vr-and-back-again-an-xrobots-tale/
