Summer Is Approaching. Are You Prepared To Relax?
[Blake Schreurs] found himself in dire straights — there was a critical lack of available hammocks in his immediate vicinity, and he wanted one. Fast. So he built a hammock stand in half an afternoon.
Initially dismayed by the cost of store-bought models, [Schreurs]’ hammock stand is perfect for woodworking-newbies and yard-loungers on a budget alike, as the build requires only a few straight cuts and some basic tools to whip up.
After cutting and laying out the lumber to make sure that it will all fit together as intended, [Schreurs] aligned and drilled holes through the pieces — don’t worry, he’s included the measurements in his post. Playing a game of connect-the-boards-with-carriage-bolts-nuts-and-washers — with a minor pause in the action to attach the feet to the base — all but finished this quick build. All that’s missing now is a hammock in which to recline!
One final note: be sure to use galvanized hardware for this — or any — project that’s expected to spend time out in the elements. Rust is not usually your friend!
Lounging in your backyard beginning to feel a little cramped? Take you relaxation on the road.
5 thoughts on “Summer Is Approaching. Are You Prepared To Relax?
  1. Up next, how to “hack” a new deck and pergola, and how to choose the right stain to withstand the elements. Meanwhile on FIne Home Building’s website, a discussion on how to write code for your home-brew Arduino remote mount head for a Yaesu FT-857D HF mobile radio.
Leave a Reply to VincentCancel reply
