Full Color PCB Business Card
[Sjaak], in electronic hobbyist tradition, started to design a PCB business card. However, he quickly became disillusioned with the coloring options made available by the standard PCB manufacturing process. While most learn to work with a limited color palette, [Sjaak] had another idea. PCB decals for full-color control.
As [Sjaak] realized early in his PCB journey, the downside of all PCB business cards (and PCBs in general) is the limited number of colors you can use which are dictated by the layers you have to work with: FR4, soldermask, silkscreen and bare copper. Some people get crafty, creating new color combinations by stacking layers for hues, but even that technique doesn’t come close to a full palette.
The commercial off-the-shelf out of the box solution [Sjaak] found was decal slide paper. For those of you not prone to candle making or car decorating, decals are printable plastic film that can be used to decorate ceramics, glass or other smooth surfaces. Both clear and white versions can be found in most hobby stores. Once obtained, an inkjet or laser printer can print directly onto the photo paper-like material, lending the decals an infinite range of colors.
[Sjaak] bought clear film and designed his PCB with black soldermask and white silkscreen. Once the PCBs had come in, [Sjaak] got to work applying the decals with a transfer method by placing one into water, waiting a bit until the decal lets loose and then are carefully applied to a PCB. [Sjaak] reports that the process is a bit trickery because the film is very thin and is easily crinkled. But, difficulties overcome, the PCB then needs to dry for twenty-four hours. From there, it’s into the oven for 10 minutes at 248 degrees Fahrenheit (120 degrees Celsius) followed by an optional clear coating. Although the process is a bit involved, judging from his pictures we think the results are worth it, producing something that would stand out; which, in the end, is the goal of a PCB business card.
With all this in mind, we think that the logical progression is to incorporate digital logic or go full DIY and CNC or laser engrave your own business card.
15 thoughts on “Full Color PCB Business Card
  1. I wish educational boards (e.g. Arduino, Raspberry Pi) would use colours to mark traces on their PCBs. For example, a red silkscreen for power, black for ground, green & blue for Tx/Rx. Manufacturing would be more expensive, but I’d pay the extra to make it easier to explain to kids “don’t short this out”.
    1. I would be surprised if it does. The printed-on layer is some sort of very thin plastic, usually stuck to the paper with some kind of sugar-based adhesive (which comes loose when you dunk it in water).
    2. Nope.. It can’t stand (too much) heat and can’t resist acetone.. So cleaning up the board ruins it too.
      I applied it after the soldering (picture of the front will follow) and made sure nothing is placed on the side the decal is applied. Not even programming pads as I assume it will be hard to cut the pads and even harder to place it right :) But hey it is only the first iteration :D
  2. LOL… I would have gone with SMDKnutselaar instead of SMDPrutser though. You don’t want potential clients to think of you as a prutser :)
    1. infinite enough for my taste.. printers are capable of printing near photoquality.
      The other side (with active components) is not quite ready yet, will write about it when done.
Leave a Reply to SjaakCancel reply
