ESP32 Makes For World’s Worst Radio Station
We can say one thing for [bitluni]: the BOMs for his projects, like this ESP32 AM radio transmitter, are always on the low side. That’s because he leverages software to do jobs traditionally accomplished with hardware, always with instructive results.
In this case, the job at hand is creating an RF oscillator in the broadcast AM band and modulating some audio onto it. From his previous experience using an ESP32 to watch video on an oscilloscope, [bitluni] knew that the microcontroller’s DACs were up to the task of producing an 800-kHz signal, and he managed to produce a more-or-less sine wave carrier with some clever code. His sketch takes data from a header file, modulates it onto the carrier, and sends it out over the ether using a short stub of wire for an antenna. The range is severely limited, but for what it is, it gets the job done and shows the basics. And as a bonus, [bitluni] included a bit of JavaScript that turns an audio file into a header file that’s ready to go out over the airwaves for all your trolling needs.
If you’re looking for a little more range for your low power transmitter and you’re a licensed amateur operator, you might want to explore the world of QRP radio.
14 thoughts on “ESP32 Makes For World’s Worst Radio Station
  1. I suspect FM would be doable, don’t need a DAC just single GPIO and you don’t have to generate usual FM band ~90MHz directly you can use a frequency with a harmonic in the FM band
    1. Sort of. It is totally doable, since the I2C engine in the ESP32 is similar to the ESP8266. You do have to rely in the reflection around nyquist so the quality isn’t that high, but it does work. One major boon of the ESP32 is the fact it has the second I2C engine so you could actually do sound AND video signals simultaneously.
  2. Combine with internet radio ESP project and a neat why to repurpose old AM valve sets without ripping them apart and spoiling the oldness.
  3. This is amazing. Are there any projects for simply outputting audio to header pins for a speaker? I see a few resources for plating audio from an ESP, but everything requires an external DAC.
  4. I am repairing old tube radio’s ans I love this esp32 appliation! I’ll try to extend it with a streaming radio input so that these old AM radio’s get a new purposein their life:=)
    1. Ever figure out how to get streaming audio? Thinking of a project where that would cut out a lot of the headache if it worked out of the box.
Leave a Reply to Nate BCancel reply
