Homebuilt Onewheel Uses Hoverboard Parts
Since Back To The Future II first screened back in 1989, people have been waiting for hoverboards to become reality. Instead, we got a dangerous two-wheeled contraption going by the same name. Wanting something a little cooler, [Bartek Plonek] decided to convert his to a one-wheel design. (Video, embedded below.)
The hack starts by machining the hub motors of the hoverboard. They’re bolted together, and used as the hub of a single larger wheel. Care is necessary to avoid cracking the motor housing during this process, as [Bartek] found during his first attempt. The wheel is then fitted to the centre of a steel frame, upon which two halves of a skateboard are attached to act as a footplate. The original hoverboard controller is still used; we’d love to know if firmware modification was required to work with the new motor configuration.
It’s a classic garage hack that results in a viable personal electric vehicle. Plus, cornering is far easier, with the DIY onewheel capable of carving back and forth quite well. We’ve seen others aim to commute using similar builds.
6 thoughts on “Homebuilt Onewheel Uses Hoverboard Parts
  1. Seems like a copy of ddiritos homemade one wheel. Also the video quality is shit, can’t see anything going on at all.
  2. The video is as cheap as the onewheel is, half the time pointing in the wrong direction particularly when working on he lathe.
  3. I’ve been skateboarding for over 35 years now and as much fun as all this looks? If I can’t ollie up a curb with it I don’t want it. I still think it’s a very cool project!
Leave a Reply to fdufnewsCancel reply
