A niche activity in console fandom is the shrinking of full-size consoles to smaller formats, taking what could once only be played on the family TV into portable formats that fit in the pocket. In a particularly impressive example of the art, [GmanModz] has made what he claims is the world’s smallest portable Nintendo 64. What makes it particularly noteworthy is that he’s done it not with an emulator or a custom PCB, instead there is a real Nintendo 64 motherboard in there having undergone a significant quantity of trimming.
The video below the break goes into detail on the state of the art in these mods, and shows how he has eschewed the latest tech and instead restricted himself to only using commercially available breakout PCBs and off the shelf modules. The N64 board trimmed down particularly aggressively, requiring a lot of fine magnet wire soldering for the various PCBs replacing the parts removed. The cartridge slot is brought out to the back of the board at a right angle, jutting out from the rear of the 3D printed case above a space for an 18650 cell and allowing an original game cartridge to be played. There is a microcontroller to facilitate a few compromises on lesser uses of the Nintendo control pads, but the result is a fully playable mini handheld console. He does admit that “The battery life sucks, it’s uncomfortable to hold […] But hey — it fits in my pocket. Does your N64?” We can’t fault him on that.
This isn’t the first portable N64 we’ve seen, but will it hold the title of smallest for long? Only time will tell.
Thanks [Matthew Carlson] for the tip.
You could make it way smaller by dumping the rom and using an emulator.
But then it wouldn’t be a true n64. If I emulate a n64 on my Pi, it’s still a Pi, not a n64
Wow! That’s some serious board trimming!
You would be better off just designing a new board and transplanting the required components.
as is mentioned in the video, where he shows smaller self designed PCB …
Now I want to see someone start milling down the lead frames to further reduce the footprint.
Haha, sick trimming tho, i cant even seem to fix a snapped psu board from a tv
Ditch the cart slot, solder in ED64 and leave SD card slot for adding ROMs
