This Week In Security: Dan Kaminsky, Banned From Kernel Development, Ransomware, And The Pentagon’s IPv4 Addresses
This week we’re starting off with a somber note, as Dan Kaminsky passed at only 42, of diabetic ketoacidosis. Dan made a name for himself by noticing a weakness in DNS response verification that could allow attackers to poison a target DNS resolver’s cache. A theoretical attack was known, where spoofed DNS responses could collide with requests, but Time-To-Live values meant that DNS requests only go out once per eight hours or so. The breakthrough was realizing that the TTL limitation could be bypassed by requesting bogus subdomains, and aiming the spoofed responses at those requests. This simple technique transformed a theoretical attack that would take 87 years to a very real 10 second attack. Check out the period video after the break, where Dan talked about his efforts in getting the problem fixed.
What may be the most impressive piece of work is how many different vendors and maintainers he convinced to cooperate while keeping the vulnerability quiet. Because of the seriousness of the problem, the decision was made to wait to publish details an additional 30 days after the coordinated patch release. It took 13 days for the vulnerability to leak, but that still gave the world enough time to prevent major problems.
Throughout his life, Dan always had a “go out and fix it” mentality that was an inspiration to others. Half of the reason that we have DNSSEC today is because of Dan’s tenacious behind-the-scenes lobbying. He was a force for good, and a hacker’s hacker.
University of Minnesota Banned From Linux
A story has been percolating for a while, and it finally resulted in a full ban on kernel patches sent from anyone at the University of Minnesota. This extreme step is the result of known-bad patches being sent for inclusion in the kernel. The original idea was to test whether a the kernel would be susceptible to a bad actor sending in a malicious patch, disguised as a fix. A paper was written about the test. Their suggested fixes don’t inspire confidence, particularly since they start off by recommending an addition to a project’s Code of Conduct, adding a promise not to push malicious code.
The paper was published back in 2020, but the ban just happened over a week ago. Why? Months after the initial incident was dealt with, suspicious patches start arriving again from the same university. The explanation was that these new patches were being generated by a new code analysis tool, but they seemed to be introducing new bugs instead of actually fixing them. Greg KH made the call that enough maintainer time had been wasted dealing with the patches, and announced the ban. My opinions are mixed. There is a certain utility in testing the kernel community against this sort of attack, but it also seems to be the right call to drop the hammer on repeated bad behavior.
The End of Emotet
Emotet was described by Europol as “the world’s most dangerous malware”. The US DOJ estimates 1.6 million machines were part of this botnet, but thanks to a global law enforcement action, it is no more. To get a sense of the size of the operation to take down Emotet, note that the number of Command and Control (C2) servers that had to be taken off-line numbered in the hundreds. The law enforcement action neutered the botnet, but there was still the problem of the malware still installed and running on machines around the world.
The solution was to host a set of C2 servers that pushed a new module to all the infected. On April 25th, this uninstall module would remove the autorun hooks, and shut down any Emotet processes on each infected machine. That process seems to have gone off without a hitch, but there is still cleanup work going on. Namely, 4.3 million email addresses were harvested from infected machines, and were found on the seized servers. Law enforcement has partnered with our old friend, [Troy Hunt] of HIBP, and those emails are now part of that service’s database.
Ransomware
It’s been a busy few weeks for Ransomware news. Apple is dealing with a $50 million ransomware demand. Acer is also facing a similar demand from the same group, REvil. In the case of Apple, the actual breach seems to have been in systems owned by Quanta, one of Apple’s suppliers. It’s been suggested that REvil is using the recent Microsoft Exchange vulnerabilities to get access into target networks.
QNAP devices have been hit hard, too. We’ve covered some of the vulnerabilities, but ransomware schemes are actively hitting the unpatched NAS devices exposed to the internet. Qlocker is one attack that is notable for its simplicity. The attackers simply ran a remote command using 7zip to generate password protected archives, and it looks like they made almost $300,000 in just a week of malicious business. A hero emerged out of the story, when [Jack Cable] tried to help a friend get data back, and discovered a vulnerability in the criminal payment system. Using the transaction ID, but with a character shifted to uppercase, was enough to confuse the system into giving up the decryption key. About 50 victims got their data back through this trick, before it was caught and fixed.
The Mystery of the Pentagon’s IPv4 addresses
The Washington Post kicked off coverage of a unique developing story. Millions of unused IPv4 addresses assigned to the US DoD were suddenly being routed for the first time. (Beware the paywall, though turning off Javascript temporarily might help you read the linked story.) The story makes much of the timing, as the routing seemed to be published in the few minutes between the swearing in of one president, and the actual end of the previous administration. My first response was annoyance that politics had been injected into what was likely a straightforward security story. It seemed that the Post was trying to find a sensational story to run. But the timing really was odd. So what’s going on here?
So first, let’s review some context. The world is running out of IPv4 addresses — has already run out, depending on how you count them. While they have all technically been assigned, in the early days of the internet, some very large blocks of addresses were assigned, and were never fully used. An A class network contains 16 million addresses, and they were given out like candy in the early days, and the DoD has several. Next, it’s worth noting that congress has entertained the idea of compelling the DoD to sell off its unused IP addresses. As the supply has run out, unused IPv4 addresses can fetch quite a high price on the open market. The last notable tidbit is that just because nothing is actively using an IP address, there is still network traffic addressed to and from there. Various network worms and scanners are continually probing the entire internet, and DDoS attacks usually use UDP packets with random source addresses. The probes and response traffic can be a valuable source of real-time information on what’s happening on the internet.
There has been coverage now by more knowledgeable voices, and even a cryptic response from the DoD. The growing consensus seems to be a trio of explanations as to what is going on. The first is the simplest. IP squatting has been known to happen, and if no one is announcing the Border Gateway Protocol (BGP) routes for an IP space, it’s much easier to illicitly make use of addresses. By claiming the IPs over BGP, the DoD is protecting those IPs. Second, it’s much easier to defend against a congress wanting to strip resources away, if you can make a valid claim you’re using those resources. And finally, it does appear that some part of the DoD is doing analytics on the Internet background noise and backscatter being received by the otherwise unused network space.
There’s one final question: Why was the project kicked off at the literal last minutes of an administration? Was this some sort of sordid plot? Not likely. A project of this magnitude would take quite some time to go from the initial idea to implementation, and would likely need to be signed off by high level administration. While I’m not sure why the switch was flipped quite as late as it was, I find it very likely that had it been any later, much of the red tape would have to be waded through a second time, and the new administration would need to sign off on it.
Drupal Core Flaw
We cover flaws in Drupal extensions, WordPress plugins, and Joomla add-ons. What is fairly rare is a serious vulnerability in the core code of one of these projects. That’s not to say it doesn’t happen. Case in point, Drupal has a Cross Site Scripting vulnerability in its core code. XSS usually shows up as a way for one user to inject javascript in a comment, that is executed when other users visit the site. This can be as benign as one user suddenly becoming the most friended account on myspace, or as malicious as a comment making the commenter an administrator when the site owner tries to moderate the trapped comment. There aren’t many details available about this one yet, but make sure your Drupal installs are up to date.
New Old Linux Backdoor
Last up this week, a bit of Linux malware was discovered, and then was found in a file submission from 2018. Dubbed RotaJakiro, this backdoor uses a handful of techniques to avoid detection, like rotating through encryption methods when contacting command and control servers. It’s a bit unnerving to know that it’s been around so long without getting noticed til now. Thankfully, there are some simple Indicators of Compromise (IoCs), like a pair of file names, and four possible md5 sums for those files. I thought it would be interesting to document the process of checking a system for these files.
My first thought was a simple combination of find to list all the files on the system, and then grep to look for the filename.
sudo find / | grep systemd-daemon
We can make this better, by getting rid of the grep command, since find has built in name matching. For bonus points, we use xargs to go ahead and calculate the md5sum when a matching file is found.
sudo find / -name "gvfsd-helper" -o -name "systemd-daemon" | xargs md5sum
There is a potential problem, if folder names contain spaces or other special characters, xargs would see the special characters as a break between inputs. Thankfully, both find and xargs have a null delineated mode, where special characters are preserved. The escaped parenthesis are needed to specify that the -print0 flag applies to both of the specified name patterns.
sudo find / \( -name "gvfsd-helper" -o -name "systemd-daemon" \) -print0 | xargs -0 md5sum
I showed this one-liner off, and was immediately reminded that find also has an -exec flag, that makes the use of xargs superfluous.
sudo find / \( -name "gvfsd-helper" -o -name "systemd-daemon" \) -exec md5sum {} \;
So this gives us a simple one-liner that will calculate the md5sum of any file with a suspicious file name. If you get a match, compare the output values to the known IoCs. Hopefully none of us will find this particular nasty on our systems, but better to know.
22 thoughts on “This Week In Security: Dan Kaminsky, Banned From Kernel Development, Ransomware, And The Pentagon’s IPv4 Addresses
  1. ” We’ve covered some of the vulnerabilities, but ransomware schemes are actively hitting the unpatched NAS devices exposed to the internet. ”
    I think I see the problem.
    1. A friend of mine got hit by it. The biggest problem as I see it is that apparently QNAP enabled UPnP (or whatever it is that punches a hole through NAT) by default. This opened it up on the routable IP address of your NAT gateway, even if you never had any interest in remote access.
  2. The xargs version is better – it will run far fewer instances of md5 to hash many files each run, whereas the -exec version will run md5 once per file – the execution overhead will add up a lot.
    1. Not necessarily. The number of files matched by those names should be pretty small, so the difference would be pretty small in the general case.
      More importantly, the `-exec` variant allows you to get results incrementally, so you can address matches as they happen in a separate terminal. The `xargs` variant forces you to wait until `find` has walked through your entire filesystem, before a single `md5sum` is run.
      Sidenote: GNU find, of course, gives you the `-exec {} +` substitute for `xargs`, but with the same performance issue – you’d be twiddling your thumbs till `find` is well and truly done.
  3. “It’s been suggested that REvil is using the recent Microsoft Exchange vulnerabilities …”
    Funny how I always read “Exchange Server” as an admonishment: “Please, exchange this server already!”.
    How anyone is still using Microsoft in a security relevant context after all that history is beyond me, really.
    1. Never dealt with the MBA crew and their magic quadrants? Marginally better than the Plaid Belt pre-C level wannabe projects that tout Facebook-at-Work as the solution to problems nobody knew existed a in sensitive data network.
    2. Please take in account that Microsoft has deep pockets.
      Do not worry how they get all that money, worry about how to get money to other companies.
      In words: Make people aware that small amounts of money matter. All those “I don’t care that those fifty cents go to Microsoft” do add up.
  4. Thanks for the one-liner to check for infection! The relevant md5 sums to look out for are:
    1d45cd2c1283f927940c099b8fab593b
    11ad1e9b74b144d564825d65d7fb37d6
    5c0f375e92f551e8f2321b141c15c48f
    64f6cfe44ba08b0babdd3904233c4857
    1. Unrelated, but why is my message showing *before* Keyboard Dogs’ and Steven Naslund’s? They were cleary already there before I wrote and submitted mine. But their timestamps seem to be in the future:
      iliis says:
      April 30, 2021 at 11:40 am
      Keyboard Dog says:
      April 30, 2021 at 11:50 am
      Steven Naslund says:
      April 30, 2021 at 12:15 pm
      (It wrote my post at 20:40 local time = 18:40 UTC)
  5. The kernel thing I was initially mixed on as I personally have a lot less faith in the inherit security of open source then most but the approach taken by this professor was just wrong and any board committee that authorized it was equally wrong.
    If I want/am asked to perform a security audit on a group I am given authorization by someone and then perform the audit while never actually doing real damage.
    If they wanted to do the same for the kernel it’s simple. Reach out to one of the leads and explain the goal and ask them to be a sort of safe guard. Push your BS patches. See how far if anywhere they go. Before they get merged into release versions of Linux have your safe guard go and scrub any changes you injected that are left. There now the Kernel team is being audited and not attacked. It’s not hard to achieve the same goal as the original paper without being a piece of garbage about it.
  6. Unless you are running commands that must be executed one-for-one (things that need xargs -n 1), using xargs is often more efficient than find -exec.
    This is because find -exec will spawn a child process for each file found, but many of the interesting commands are capable of accepting many files as arguments.
    Example
    time find / -exec ls -l — ‘{}’ ‘;’
    will fork and exec one ‘ls’ for each file on your system.
    time find / -print0 | xargs -0 ls -l —
    will launch far fewer copies of ls (and thus save lots of fork/exec overhead).
    In many cases, despite doing the same total amount of useful work, the second command will complete in far fewer seconds, and if the system is non-idle, it will cause less of a slowdown to other processes.
  7. One day one of these ransomware groups will hit a large company who have less compunction about resolving issues themselves. And they’ll find a “private security contractor” on their asses. And if the big company has any sense, they’ll live stream it and sell tickets.
    1. ” And if the big company has any sense, they’ll live stream it and sell tickets.”
      Nah, just record one guy being “dealt” with and send the video to other involved parties and the word will spread without legal hassles.
  8. The DoD address annoucement is really a non-issue. It is really best practice to announce your assigned address blocks into BGP and null route them. This ensures that you have a foothold on your address space and interrupts someone attempting to use your address blocks. As far as DoD selling off unused space, I am fine with that as long as they realize they can never get that space back. For those critical of the DoD holding that much space, just remember that back in those days, all routing was classful thus requiring large Class A assignments. There was also no concept of commercial usage at the time of the assignment. The multiple Class A assignments were quite reasonable when DoD envisioned using them for different security levels in the different departments before the advent of classless routing.
    I was there when this was ARPANET and I worked on some of the BBN nodes used by the US Air Force.
    1. Wouldn’t you think maybe the DoD might be moving to IP6? Seems that could a logical move ‘within the department’. Then no longer bound by IP4 limitations. Just a thought.
      As for ransomware, I’d think a large company like Apple would have a ‘non-issue’ as I am sure there must be a ‘backup’ somewhere. More like an irritation than a priority event.
      1. The DoD still has systems running SCO unix. They’re *terrible* about updating legacy hardware, because there’s so much red tape to go through. It’ll be decades before they could go ipv6 everywhere.
          1. Yep. Working on a SCO box really makes you grateful for modern Linux. I once moved a dieing sco system to KVM virtualization. There was much hair pulling and consternation.
      2. It’s a supplier, who might not be as protected.
        Welcome to 2021, where to supply to a large company you have to carry multi-millions in cyber insurance. :/
