Wooden Monowheel Build Is Simplicity Itself
Monowheels are nothing new, first being patented in the middle of the 19th century, but never really went mainstream due to, well, quite a lot of obvious issues. We’ve got problems with forward visibility, stability, steering, especially at speed, and the hilariously-named ‘gerbiling’ where the rider can spin around inside the wheel akin to a gerbil in a wheel. Fun times! But obviously that didn’t stop [The Q] from adding to the monowheel corpus by building one out of wood.
Sometimes people take on these projects simply for a laugh, like this bright orange one we covered a while back. Sometimes they’re powered by a motor, be it electric or internal combustion. Some are hand-cranked, some are pedal-powered, its all been tried.
[The Q] is no stranger to interesting wooden builds, and this video from a year ago shows him building a very simple direct-pedal-drive monowheel. The vast majority of the structure is wood, glued and screwed the old-fashioned way, with a bit of metalwork where necessary. We particularly like the simple counterweight solution which doubles up as a parking brake. It may look a little ungainly, but we can’t think of a simpler solution that would make much sense.
The build video after the break is six and half minutes of well executed videography for your viewing pleasure.
9 thoughts on “Wooden Monowheel Build Is Simplicity Itself
  1. Those two boards extending out front could be an attachment point for a pony.
    But the passenger/driver would risk getting “rained on” by the exhaust falling off the wheel.
    Instead, the boards could be extended out the rear of the conveyance to attach a pony and avoid that problem,
    but that would be putting the cart before the horse.
Leave a Reply to HirudineaCancel reply
