Simple But Stylish Numitron Clock Can Display Time, Date And Temperature
A Numitron clock showing "30 degrees C"
While it seems like Nixie tubes get all the attention when it comes to making retro-style displays, there are plenty of other display technologies that can make a good-looking retro design. Take the Numitron tube: introduced by RCA in the early 1970s, these display tubes might look superficially similar to Nixies but work in a completely different way. The Numitron uses incandescent elements that make up seven-segment displays.
The main advantage Numitrons have over Nixes is that they don’t require a high-voltage supply, which makes them much easier to hook up to modern low-voltage electronics. [mircemk] used this to his advantage when he built a simple clock using four numitrons that can display the time, the date, and the ambient temperature.
The brains of the device are formed by an Arduino Nano coupled with a DS3231 battery-backed real-time clock module. For now, the time has to be synchronized by connecting the Arduino to a PC and reprogramming it, but [mircemk] has plans to update the design with pushbuttons to allow the user to set the time manually.
Four shift registers are all that’s needed to interface the microcontroller to the display tubes, thanks to their low-voltage operation. They do need quite a lot of current, so [mircemk] used the high-power TPIC6C595 instead of a  regular 74HC595 chip. We wonder if the tubes’ high power consumption could be the reason why the temperature in his lab seems to hover around 30 °C.
A simple but stylish plastic enclosure completes the design. Since Numitron tubes are relatively low-cost and no other specialized components are needed, this could be one of the cheapest and easiest ways to make a retro display tube clock. Although we’ve seen a couple of Numitron clocks and even watches before, today’s build is a great example of how simple such a design can actually be.
6 thoughts on “Simple But Stylish Numitron Clock Can Display Time, Date And Temperature
  1. “ince Numitron tubes are relatively low-cost”. I don´t agree. Cheapest (IV-9) are 10USD a piece for just 7 segment of glowing filament goodness is not what I consider a bargain.
    1. Yikes. Seems display tubes have gone up in price during the Pandemic. Like by a factor of 3-4.
      Guess the writer of the article has not kept up with that development.
      1. I think the supply of numitrons has simply been depleted. I built a few clocks with them and tubes were $3-$4 a piece back then. Went looking for them recently and got sticker shock. Good thing I used some constant current shift registers to drive them so the segments should last a long time.
  2. I’ve done the same thing with my numitron clock, regulate down to say 3V and you don’t need any resistors. Though i used HEF4794 shift registers which are nice cause they got integrated led drivers, so unlike with a 74hc595 i wasn’t going overspec. The TPIC make a good choice too as they are a level greater power (rather overkill than underkill!)
    It is a worthwhile to remember that although you could use resistors to limit current for stuff like leds and numitrons. To save parts it can work to just drop the voltage prior too. Be it via diodes, or a (switching) regulator.
    A personal tip: Remember that shift registers got Output Enable pins. Although first instinct is to just short to ground for permanent on, you can control them with a PWM signal to strobe the outputs for variable brightness.
Leave a Reply to FoxhoodCancel reply
