Pi Powered 1:35 Scale Panther Tank
Tank aficionado [Daniel Zalega] has enjoyed playing around with armored fighting vehicles in the digital realm for years, but only recently realized he had the technology and skills necessary to take his passion into the physical world. Albeit on a slightly reduced scale. So he bought a 1:35 plastic model kit for the German WWII Panther tank from Tamiya, and started working on a way to make it move.
Luckily for [Daniel], the assembled model is essentially hollow. That gave him plenty of room to install the geared drive motors, batteries, motor controllers, voltage regulators, a servo for the turret, and the Raspberry Pi Zero that controls the whole show. Those with an aversion to hot glue would do well not to look too closely at the construction here, but it gets the job done. Besides, it’s not like this little Panther is going to see any front line combat.
Another element of the model kit that made it well-suited to motorization is the fact that it had real rubber treads. That meant [Daniel] just had to pop some holes in the side of the tank, and figure out how to mount the drive sprockets to his gear motors. Unfortunately it looks like the wheels are static on this model, meaning the tread has to be dragged over them. That’s certainly robbing the tank of some power and speed, but in the video after the break, you can see its movement is still fairly realistic.
To control the tank, he points his phone’s browser to a simple page running on the Raspberry Pi. By simply dragging a finger on the screen, you can operate the tank’s two independent treads and rotate the turret. [Daniel] said his original plan was more elaborate, with the web page displaying a live video feed from an onboard camera as well as the readings from various sensors. But at least for now, things are kept as straightforward as possible.
This certainly isn’t the first souped-up toy tank we’ve seen here at Hackaday. From gorgeous steam powered machines to this Tiger tank with a laser-assisted aiming system, these small tracked platforms have long been a favorite of hardware hackers.
6 thoughts on “Pi Powered 1:35 Scale Panther Tank
  1. I have 3 R/C tanks in 1/16 with binary controls, thought about modifying their controls when I have finished a few other projects. Had a Xbox Controller in my mind. I’d need a lot more spare time for all the stuff I want to do.
      1. I just used YT editor and cropped the loudest part (sadly there’s no option to modify volume), may take a few hours before it shows up changed.
  2. Enjoyable video ( though, as commented above, the explosion bit was not necessary IMO ). As a RC boat and plane enthusiast, I like the idea of using WiFi/ mobile for RC control at least for land/water based models.
    If you mounted one motor at each end, you could go down to 1/72 scale using ESPxx module for web server/rc receiver rather than RPi.
Leave a Reply to thetankdudeCancel reply
