2022 Sci-Fi Contest: A Friendly Wall Drawing Robot
Drawing on walls is fine for children, but adults tend to get bored quickly with such antics. Even more so when they realize who is responsible for cleaning up afterwards. Instead, consider delegating those duties to a friendly helper by the name of Fumik, as [engineer2you] has done.
Fumik, who looks like a cute little jellyfish, can draw pictures up to 5 meters wide and 3 meters high, making for a massive canvas. Powered by an Arduino Mega 2560 outfitted with a CNC shield, a pair of stepper motors drive pulleys with toothed belts to move Fumik to various positions along the wall. Another smaller stepper motor is used to drive the pen forwards and backwards as needed. Fumik can be programmed to trace out various designs in SVG format. These must be converted to code and programmed into the Arduino, at which point Fumik can begin work, drawing on the wall with its pen.
It’s a fun build, and based on photos shared by [engineer2you,] Fumik is quite able at drawing clean and neat designs without a lot of smudging or jagged lines. As a bonus, it’s easy to swap out the pen, so multicolored designs can be drawn in multiple passes.
We’ve seen other robot drawing builds before, too, like this capable portrait artist. Video after the break.
8 thoughts on “2022 Sci-Fi Contest: A Friendly Wall Drawing Robot
    1. I suggest to create a new tag : ‘duplicate’ for content writers to highlight this is again about an old topic.
      Maybe ‘triplicate’ for this specific one.
Leave a Reply to rasz_plCancel reply
