Add Conductive Traces On Vacuum Formed Plastic With 3D Printing
6 panel diagram of process
Surface conductors on vacuum formed parts appear in many hacks, from cosplay armor to 3D touch pads and smart objects. But making them has always been painful. Either they had to be hand painted after forming, which looked sloppy and was labor intensive, or they had to be printed with some difficult to use stretchable ink tech. [Freddie Hong] and his group have another solution, using tech most hackers already have – a 3D printer and a vacuum former.
plastic tray with electrodes to sense foil wrapped chocolates
Smart tray created by this method.
They 3D print the traces with conductive PLA filament directly onto a base plastic sheet, and then vacuum form the whole thing. The filament is happy to deform when heated – it’s printer filament.
We like this process.  We’ve found conductive filament isn’t reliably resistive across vertical layers, but is reliable in the XY plane. Their method only requires one layer. Also, they suggest 3D printing a layer of non conductive PLA atop most of the conductor, like a PCB solder mask.
Conductive filament has a fair bulk resistance. They suggest electroplating it before applying the top mask layer. They also are exploring 3D printing logos, stripes, and such with colored filament, or even making surface detail like rivets on model parts or adding thickness where the plastic thins during vacuum forming.
Designing the 3D print requires guessing what bit of plastic sheet ends up where in the vacuum formed final part.  His group used a commercial program, t-sim,  to do the prediction and Grasshopper to import the result into Rhino3D. This seems a lot for a home hacker. Drawing lines on a test sheet and vacuum forming seems simpler.
We’ve looked at vacuum forming before. We did a piece on 3D printing bucks , and covered [Ted Brull]’s Kevo vacuum former back in 2015.
Thanks to [howielowe] for the tip.
3 thoughts on “Add Conductive Traces On Vacuum Formed Plastic With 3D Printing
  1. “We like this process. We’ve found conductive filament isn’t reliably resistive across vertical layers, but is reliable in the XY plane.” Do you have a source for this? I am currently writing a proposal based on conductive filament and documentation of this would be huge for me.
  2. The original article authors report this as well.
    I don’t have a source on this end. I was a bystander in a maker space when someone was 3D printing ESD filament and trying to reduce variation in Z axis resistivity.
Leave a Reply to Anne OgbornCancel reply
