Probably The Simplest Radiation Detector You Already Own
Over the years we’ve featured quite a few radiatioactivity detectors, which usually include a Geiger-Muller tube, or perhaps a large-area photodiode. But in the event of radiation exposure from a nuclear attack, how does the man in the street gauge the exposure without owning a dedicated instrument? This was a question of note at the height of the Cold War, and it’s one that [Dr. Marshall Brucer] answered in a 1962 paper entitled “When Do You Leave A Fallout Shelter“. The full paper is behind a paywall but the part we’re interested in is on the freely available first page.
Dr. Brucer‘s detector is simplicity itself, and it relies on the erosion of a static electric charge by radiation. Should you rub a plastic comb in your hair it will accumulate enough charge to pick up a small piece of paper, and under normal background radiation the charge will ebb away such that it will drop the piece of paper after about 15 seconds. His calculation is that once the field reaches around 10 roentgens per hour it will be enough to erase the charge and drop the paper immediately. There’s a comtemporary newspaper report (Page 7, just to the left of the large advertisment) which tells the reader that since the exposure limit is 100 roentgens (one sievert), this test failing indicates that they have nine hours to create a better shelter. For obvious reasons we can’t test this at the Hackaday bench, but those of us who remember the days when such topics were a real concern will be searching for a handy comb anyway.
Thanks [Victor Matthew] for the tip.
77 thoughts on “Probably The Simplest Radiation Detector You Already Own
  1. Fine as long as you have hair, any suggestions for those of us with bald heads (and wishing to avoid the ignominy of combing our pubes), or for those whose hair has already fallen out due to the radiation?
    1. Make an electrometer with a couple strips of aluminum foil, a piece of solid wire and a class jar or flask and a cork. I used to have my whole HS physics class make them. It takes about 15 minutes to do a good one then the rest of the period is experimenting with them. They were very surprised at making an actual scientific instrument. Maybe the Googler has something …. similar to this oddly complicated one. https://www.youtube.com/watch?v=GA9Kli0XPbw
      1. Better idea….
        DONT SPREAD NUCLEAR CONTAMINATION AROUND!!!
        “Yeah, but failing that….”
        NO! Just dont fucking do it in the first place!
        Humans, pfft……and they have the nerve to call themselves ‘great’ apes……
  2. I hadn’t heard this idea before, interesting. I was going to mention humidity has a big effect on this. He does mention humidity near the end of that first page that is displayed.
    We all need to create a baseline, run a test in our fall-out shelter now, how many seconds does my comb hold 1/4 of a facial tissue, for comparison to when the bombs have fallen.
  3. “those of us who remember the days when such topics were a real concern”
    After Russia’s comments last week, they are a real concern again. Hopefully nothing comes of it but it’s definitely back on the table.
    1. As we have known since the 90s would happen if NATO pushed forward into that country and/or Georgia. Countless national security experts have commented on it (including the current admin’s head of the CIA).
        1. NATO isn’t an innocent bystander in the process. They’ve long refused membership applications, but now actively engage. So yes, by now taking in members in an eastward moving direction, they are pushing towards Russia’s borders.
          1. NATO is not pushing forward. Russia can recruit countries to join an alliance. Russia just chooses to do it by force which is why countries VOLUNTARILY join NATO.
        1. Even a human hair is too stiff as a flexure for a Kearny-type ‘fallout meter’
          It’s highly doubtful a hinge or flexure capable of supporting a magnet will be budged by the electrostatic forces involved. You’d be better off omitting the magnet and just observing it optically.
          So the question remains: How would a Hall sensor be used here?
          1. Obviously, you’re just not thinking creatively enough.
            Following your suggestion of using optical sensing, you have a camera watching for the falling item. Then you put your camera on a servo mount to keep the falling item centered in its view. (You can use OpenCV to find the object in the image.) Then you put a magnet on the camera mount, and use a hall sensor to detect its position.
            You see, there is no situation so simple that you can’t over-complicate it by adding extra parts. There’s an engineer by the name of Goldberg who did a lot of great work in this field.
            Sure, someone else might approach this problem with an LED and a light sensor, but what fun is that?
          2. “Sure, someone else might approach this problem with an LED and a light sensor, but what fun is that?”
            Using an LED as a light sensor too?
    1. A very simple circuit with a JFET (with the gate disconnected and used as an antenna), a LED and a 9 V battery can serve as a simple electroscope. In post-nuclear times, with a dwindling supply of new batteries, an electroscope can also be constructed with a strip of aluminum foil. The self-discharge time of either can be a good indicator of the level of ionizing radiation.
          1. And for very high dose rates. From the paper it can be seen that LDRs are inexpensive and reliable sensors for dose rates above 50 cGy/min. Roughly, the equivalent of 3000 Roentgen/hour. A dose of 1000 Roentgen, for example, is considered fatal. If you can measure a variation in the dark current of an LDR, you’ll be dead in no time.
  4. Probably The Simplest Radiation Detector You Already Own is your cell phone camera.
    At the dose rates this ersatz radiation detector is said to detect, your cell phone camera images will be full of speckles.
      1. Well, you don’t have to be in the same place, so you can be safe.
        And you don’t have to worry much about the phone: I zapped a 1 GB SD card with 10 kR (~100 Sv) (i.e, enough to promptly kill a human). It survived with not a single bitflip. Not quite so extreme doses to digital cameras (SLR & P&S) and a HP41C calculator were similarly uneventful. I should try again with a modern phone.
  5. You can’t generate a static charge with a comb anymore because combs are not made of rubber anymore. This article says “plastic” comb, but Marshall Brucer lived in a time when combs were made of rubber. If you go to Wikipedia you’ll see that says to use a rubber comb. It’s an important distinction.
    If you want this to work, rub a rubber balloon on your head, not a plastic comb.
    1. Some combs do it. Depends on the plastic, but that isn’t usually obvious from the comb. I know I demoed it for some kids in the fam a few months back with a purple comb I had, but this black one that’s to hand now isn’t doing much, wonder if the pigment in it is carbon black. Anyhoo, used to be an am-sci site with a handy table of best ones to use with each other, what materials charge each other up best, but having trouble retrieving it. IIRC polystyrenes get a decent charge from hair/wool, but can’t remember the others.
  6. This won’t work. If there is so much radiation that the air is conductive you are directly in a fallout zone and nothing will change that. Perhaps a few months of rain that force the particles deep into the soil. Hopefully snow covering it preventing dust being blown up again from wind.
    1. there is a stark difference between 100s of mSv/h and single to double digits of Sv/h…the former means you could probably leave the fallout zone without any serious ARP, while the latter will probably give you a lethal dose before you can get away.
      A few weeks at most will do this as the short-live isotopes decay.
      You obviously still need a way of not absorbing the radionuclides while traversing the fallout zone.
  7. Do not Google for SciHub and put in the searchbox of this illegal website the DOI number of the closed access paper. It’s completely illegal and I have to warn you about the consequences. I repeat, DO NOT GOOGLE FOR SCIHUB.
  8. I wonder if one can do something with a gold leaf electroscope type setup… say you use chocolate bar tinfoil, which is typically quite thin, in place of gold leaf, or possibly metalised mylar… and you have an optical sensor to determine when the leaf drops (apparatus discharged) then one could maybe have an ATTiny85 (or a 555 timer with stable oscillator) topping up the charge at suitable intervals from a voltage multiplier…. or motorise a medicine bottle against a discarded silk tie belt, so then if leaf drops in interval radiation is dangerous level… this sets off the beeper though the digital magic of your ATTiny85 or analog magic of your 2N2222 light detector.
  9. 10 Roentgens per hour?!?! That is extremely hot and I doubt ones long term outlook would be that good. I have two mil surplus AN/PDR-27 units and they top out at 500 milliroentgens. Even that is a level I would not want to be around too long.
    1. Mind that 100 mSv is the lower limit of statistically significant cancer risk. Anything below that is extrapolation, and the workplace radiation safety limits for lifetime exposure were arbitrarily placed at 20 mSv simply to err on the side of caution. You need 1,000 mSv total exposure to have 5% chance of eventually developing cancer.
      10 Röentgens per hour is 10 mSv per hour. All the panic about how you’d be walking dead within hours is based on a misunderstanding of the radiation safety standards. Even after a few days, you’d still have a 95% chance of nothing special happening to you.
      To put things into perspective, 1 Sv is equal to 1 Gray of absorbed dose, which is 1 Joule of energy per kilogram of body mass. 10 mSv/h is about 0.8 Watts for the average person. This is roughly the same full body dose rate of ionizing radiation as you would get by laying flat on the ground naked on a sunny day (UVB light).
      1. Dammit, my brain isn’t working. If it’s 80 Joules per hour, then it’s 22 milliWatts, not 0.8W.
        Meanwhile, the sun is still putting out about 1.5 Watts of UVB per square meter on the ground, so 100 mSv per hour is in the same ballpark as getting a sun tan. Slightly less.
        1. No, 10 mSv/h is 0.22 Watts and 100 mSv/h is 2.2 Watts for an 80 kg person.
          Now it is correct.
          So much for the ease of SI units when different quantities are still arbitrarily 10,100 or 1,000 times smaller or larger, and there’s a factor of 3.6 tucked in there somewhere.
  10. Don’t try a cockroach to sense ionizing radiation.Their little exoskeleton is an efficient shield. At Macquarie uni they placed cockroaches in a pit then gave em heaps. The critters lasted over a month.
