MS-DOS Client Brings ChatGPT To The IBM PC
A ChatGPT client running on an IBM Portable PC
AI-powered chatbots are clearly the future of computing, and it’s only a matter of time before you’ll see them appear on every internet-connected gadget. If you thought you were safe from this by sticking to an ancient MS-DOS PC though, think again: [Yeo Kheng Meng] has recently written a ChatGPT client that runs on DOS.
[Yeo Kheng Meng] didn’t cheat by simply running MS-DOS on a modern PC, either: he tested the client on a real 1984 vintage IBM 5155 Portable PC. This semi-portable PC/XT model sports a 4.77 MHz 8088 CPU, 640 kB of RAM and a CGA video card with a built-in monochrome monitor. An NE2000 ISA network card, running in 8-bit mode, enables the Portable to connect to the internet.
Running the client couldn’t be simpler: just run doschgpt.exe and type in your question. [Yeo Kheng Meng] developed this program using the Open Watcom C/C++ compiler, which was the compiler of choice for most DOS game developers back in the day. Networking support was provided by an era-appropriate packet driver together with MTCP, a TCP/IP stack developed by [Michael Brutman] for DOS-based internet applications.
Connecting to the ChatGPT API and parsing the results was pretty straightforward, but implementing the required TLS encryption was not. Even if there was a library available for MS-DOS, the 5155 wouldn’t have enough CPU power to run it in real time, so [Yeo Kheng Meng] decided to run that bit of the networking stack on a modern PC and send an unencrypted HTTP stream to the DOS client.
The end result is a delightful retro-futuristic setup that seems to have come straight out of a 1980s science fiction movie. We can already picture it together with a Commodore 64 reporting the news and an IRC server running on an IBM PC.
16 thoughts on “MS-DOS Client Brings ChatGPT To The IBM PC
    1. Technically, yes, DOS files are in 8+3 Format.
      However, some versions, like FreeDOS for example, do support LFNs. Running FreeDOS on 808x system is a bit of a slow experience, I assume. Especially if FAT32 is being used. Nevertheless, there’s a pure 16-Bit build, AFAIK. I’d rather use an 80286 system for that, though. But an 80286 could run OS/2, too. ;)
    1. The old PC is doing the work of forming requests and parsing responses. The proxy is just to handle the HTTPS security; it’s transparent except for that. The machine is doing full TCP/IP too.
      If ChatGPT had open HTTP endpoints it would work directly.
Leave a Reply to MHCancel reply
