A Paddle Wheel Ground Effect Vehicle
Who said paddle wheels were just for leisurely riverboat cruises? [rctestflight] is smashing that image with a high-speed twist on the concept, using paddle wheels to propel a ground effect vehicle across water. In the video after the break, witness this blend of old and new as he tests various designs.
Over the past few years he’s worked on a series of ground effect vehicles which exploits the increased lift and reduced drag when flying close to a surface. Unlike full-sized counterparts, smaller RC models struggle to stay in this sweet spot due to less pronounced self-stabilizing feedback loops. This means a small scale vehicle tends to touch the water rather often, and bleeding a lot of momentum in the process.
He wanted to convert these losses into gains by giving the vehicles a boost of speed whenever it touches the water. It’s a popular trick with RC cars which will hydroplane for long distances as long as they can maintain speed. All the designs still required air propellers for takeoff and to help maintain speed. The final design didn’t really need the paddle wheel when the air and water was calm, but it definitely helped when things got choppy. He is already experimenting with different paddle designs but also plans to test some other types of surface drives.
For covered a number off small scale ekranoplans, including a previous version by [rctestflight] that uses lidar for altitude control. He has also collaborated with [Think Flight] to build a autonomous small scale prototype for a maritime shipping startup.
17 thoughts on “A Paddle Wheel Ground Effect Vehicle
    1. Simply replace ag1 through something healty, water for example and enough sleep, little bit teamsport and learn to cook non processed foods. Visit your family regularly, your frinds. Find a country to work with non toxic worklife. And keel going.
      If you have the option being depressed in your city or somewhere with more sunshine on this globe, choose sun.
    2. I read your comment before starting the video. I had no idea what is AG1.
      The long commercial for AG1 so near the start of the video ended it for me.
  1. I was talking with a farmer who was exploring if it would be possible to put a spray rig on a hovercraft frame for spraying and spreading fertilizer with minimal groundpressure/compaction issues early in the season when the ground was wet. He figured he could do it but there was the problem of “side-slip” in any sort of slope, and the difficulty of keeping straight rows to get even application.
    I suggested side-wheels to act as a sort of keel, but he figured they already made balloon tired spreaders so that would not be much of an improvement to justify the cost and time.
    I thought it was a wonderful project, I could imagine LARPing Hammer’s Slammers’ Hovertanks across grass seed fields in the winter.
    1. “for spraying and spreading fertilizer with minimal groundpressure/compaction issues early in the season when the ground was wet.”
      It’s called a crop dusting helicopter.
      1. Helicopters run very high per hour, and this was prior to drones. the goal was to get something that would be cheap to build run and service, and would have low ground pressure. Locally the farmers use equipment they call Ducks, that have three balloon wheels and really big spray booms, and they still leave some sort of rut. They are also very big, and expensive.
        I think drones are a better option today, but I loved the idea of a hoversprayer.
  2. Cool Project, as I’ve long been interested in the improved efficiency of Ground-Effect flight! It’s my understanding that Engineering Models are supposed to work at true scale. However the size or period of the waves/swells, in relationship to the model, as well as any flight oscillation dynamics of ground-effect lift, could present additional design parameters and challenges. Usually, because it is a model, things can be fudged in its favor, over that of a full sized unit. Such as a lower than normal center of gravity, extra lift, increased stability compensation, etc. to improve the designs inherent stability and Transform response-time.
Leave a Reply to SunnyCancel reply
