A Long-Range Meshtastic Relay
In the past few years we’ve seen the rise of low-power mesh networking devices for everything from IoT devices, weather stations, and even off-grid communications networks. These radio modules are largely exempt from licensing requirements due to their low power and typically only operate within a very small area. But by borrowing some ideas from the licensed side of amateur radio, [Peter Fairlie] built this Meshtastic repeater which can greatly extend the range of his low-power system.
[Peter] is calling this a “long lines relay” after old AT&T microwave technology, but it is essentially two Heltec modules set up to operate as Meshtastic nodes, where one can operate as a receiver while the other re-transmits the received signal. Each is connected to a log-periodic antenna to greatly increase the range of the repeater along the direction of the antenna. These antennas are highly directional, but they allow [Peter] to connect to Meshtastic networks in the semi-distant city of Toronto which he otherwise wouldn’t be able to hear.
With the two modules connected to the antennas and enclosed in a weatherproof box, the system was mounted on a radio tower allowing a greatly increased range for these low-power devices. If you’re familiar with LoRa but not Meshtastic, it’s become somewhat popular lately for being a straightforward tool for setting up low-power networks for various tasks. [Jonathan Bennett] explored it in much more detail as an emergency communications mode after a tornado hit his home town.
23 thoughts on “A Long-Range Meshtastic Relay
  1. Local codes may be different, but it isn’t uncommon that power limits for unlicensed radio devices refer to e.r.p. (effective radiated power) rather than the transmitter power. This makes using directional antennae less effective (at best, because it requires transmitter output power to be limited) or illegal (at worst). Know, what you are doing.
    1. Good thing the FCC has no enforcement officers and they can’t hardly enforce real issues much less these matters.
      1. Yes, no FCC in Canada but there is an equivalent agency. Enforcement in both countries tends to be driven by complaints.
        1. The FCC has not enforced anything(outside of TV/FM/Pub.safety) in
          30 years. If someone is making ALOT of money from it the FCC
          could care less. Real shame… :(
  2. It’s generally not a good idea to leave those cheap OLED displays running all the time. They’ll wear out in a year.
    Ask me how I know.
  3. I seem to be missing something; how are these a repeater unit?
    Are these two transceivers Bluetooth linked together to share the payloads?
    Is [Peter] just expecting RF to leak from the first unit to the second (clearly the directional antenna isn’t perfect)?
        1. The two units communicate through RF. The only time RF is not used is to the cell phone or computer at the ends…then it is BT, direct, or WIFI.
    1. The LORA band is licensed based on ERP so more gain would technically put you over the legal limits but then again the FCC barely enforces spectrum usage.
  4. I too have seen a range of YT videos in the sidebar mentioning ‘meshtastic’.
    And all I could think was how much that word irks me.
    Not sure why but I do so dislike it.
    1. LANtastic was a notorious PO(steaming)S networking package, many years ago.
      I’m sure there are other examples of terrible ‘tastic’ products. Can any body think of a ‘tastic’ that didn’t suck? I’m drawing a blank.
  5. How does one get started on meshtastic?
    How do we spread this technology to neighbours and friends and not foes?
    How do we ensure that the foes do not succeed neither in joining nor in DDOS attack etc?
    How can we make a DIY version by use of standard components for a small computer / embedded / network enthusiast who knows Arduino, WiFi, BT, and who gave played a tad bit with LoRa and who does not like LoraWan as it suddenly centralizes the network again?
Leave a Reply to thomCancel reply
