VFD Tube Calculator Shows Off Wide Array Of Skills
With all the tools and services available to us these days, it’s hard to narrow down a set of skills that the modern hacker or maker should have. Sure, soldering is a pretty safe bet, and most projects now require at least a little bit of code. But the ability to design 3D printable parts has also become increasingly important, and you could argue that knowledge of PCB design and production is getting up there as well. With home laser cutters on the rise, a little 2D CAD wouldn’t hurt either. So on, and so on.
If you ever wanted an example of the multitude of skills that can go into a modern hardware project, take a look at this gorgeous Vacuum Fluorescent Display (VFD) tube calculator built by [oskar2517]. As fantastic as the final product is, we were particularly impressed with everything it took to get this one over the finish line.
A .7 mm walnut veneer covers the pieced together plywood frame.
It’s got it all: 3D printed parts, a laser cut wooden frame, a custom PCB, and even a bit of old school woodworking. To top it all off, the whole thing has been meticulously documented.
But what’s perhaps most impressive here is that [oskar2517] was approaching most of these techniques for the first time. They had never before worked with IV-12 tubes, designed an enclosure in 3D, had parts laser cut, applied wood veneer, or designed a custom PCB. They did have solid experience writing code in C at least, which did make developing the Arduino firmware a bit easier.
Although they might look outwardly similar, VFD tubes like the IV-12 are easier to work with than Nixie tubes thanks to their lower operating voltage. That said, a look through our archives shows that projects using Nixies outnumber VFD tubes by nearly four to one, so there’s no shortage of folks willing to take on the extra effort for that sweet warm glow.
3 thoughts on “VFD Tube Calculator Shows Off Wide Array Of Skills
  1. The complaint about the bent tube pins not making an easy fit on the chinese made sockets is wrong.
    The rule of thumb when using those badly designed chinese made sockets; take an old defect tube and do many cicles place/remove before seating ANY ancient tube You want to work on it.
    Originally the clocks made in the USSR were using IV-12 VFD on special sockets that allow sliding easily into like into a pair of bladdes.
    That can be found on the elektronika G9.02 clock and a few others, i.e. on the successors models with the red/blue/white plastic case.
    See the picture on Danyks website or see the clock I do own personally (no picture).
    https://danyk.cz/stare_digi_hodiny55.jpg
Leave a Reply to RajCancel reply
