Amazon Receives FAA Approval For MK30 Delivery Drone
It’s been about a decade since Amazon began to fly its delivery drones, aiming to revolutionize the online shopping experience with rapid delivery of certain items. Most recently Amazon got permission from the FAA to not only start flying from its new Arizona-based location, but also to fly beyond-visual-line-of-sight (BVLOS) missions with the new MK30 drone. We reported on this new MK30 drone which was introduced earlier this year along with the news of the Amazon Prime Air delivery service ceasing operations in California and moving them to Arizona instead.
This new drone has got twice the range as the old MK27 drone that it replaces and is said to be significantly quieter as well. The BLOS permission means that the delivery drones can service areas which are not directly visible from the warehouse with its attached drone delivery facility. With some people within the service range of the MK27 drones having previously complained about the noise levels, we will see quickly enough whether the MK30 can appease most.
As for the type of parcels you can have delivered with this service, it is limited to 2.27 kg (~5 lbs), which is plenty for medication and a range of other items where rapid delivery would be desirable.
23 thoughts on “Amazon Receives FAA Approval For MK30 Delivery Drone
      1. If you hear modern heat pumps or a/c units and you don’t think, “Thank goodness for modern technology”, then either you are blessed to live somewhere extremely temperate or are just whining to whine.
        Only negative I see with them is the bad habit of not designing homes to be as efficient and passively temperature regulated. However even a properly designed house absolutely needs one of these units.
    1. How many propellers do you think are supersonic? I know of exactly one, and it was called “Thunderscreech” for a reason. Supersonic propellers are a pretty terrible idea.
      Drones are quite loud even though I am 99.9% certain that 100% of them have subsonic propellers
      1. The propeller tips go supersonic, that is what they are referring to. Yes, the Thunderscreach was loud. So loud it made people physically ill. The aircraft was the only “Supersonic” propeller driven aircraft built. 😊👍
  1. Birds are the primary hazards to aircraft. FAA: “In 2022, 17,190 strikes were reported (just in the US). The annual cost of wildlife strikes to the USA civil aviation industry in 2022 was projected to be 67,848 hours of aircraft downtime and $385 million in direct and other monetary losses.”
    These drones for routine deliveries are such a pipe dream. One hits a bird, falls to the ground, damages property or harms someone and that’s the end. Plus, criminals will follow for “free stuff” and people trying to relax in the sun on their properties will just love the noise if the highly improbable happens and there are a lot of these flying around. In that case, in the US at least, they’ll probably be used for skeet practice.
Leave a Reply to DHCancel reply
