Chocolate-Coating Machine Mk. 2: The Merry-Go-Round
A chocolate coating machine works in the round to enrobe mint Oreos.
This holiday season, [Chaz] wanted to continue his family’s tradition of enrobing a little bit of everything in dark chocolate, and built an improved, rotating chocolate-coating machine.
You may remember last year’s offering, aka the conveyor belt version. Although that one worked, too much chocolate was ultimately lost to the surface of the kitchen table. [Chaz] once again started with a standard chocolate fountain and bought a round wire rack that fits the circumference of the bowl at the bottom. He snipped a hole in the center large enough to accommodate the business part of the fountain and printed a collar with holes that he cleverly zip-tied to the rack.
[Chaz] also printed a large gear to go around the bowl, a small gear to attach to a six RPM motor, a motor mount for the bowl, and an air blade attachment for a portable Ryobi fan. The air blade worked quite well, doing the double duty of distributing the chocolate and thinning out the coating. Plus, it gives things a neat rumpled look on the top.
Want to make some special chocolates this year, but don’t want to build an enrober? Get yourself a diffraction grating and make some rainbow goodies with melted chocolate.
17 thoughts on “Chocolate-Coating Machine Mk. 2: The Merry-Go-Round
    1. If you’re ever find yourself at a buffet with a chocolate fountain, you should know somebody has coated their fried chicken in it. Oh, and their fingers, which they’ll lick clean and stick back in the chocolate.
  1. the video doesnt load in feedly or any rss reader or on your website and asks for a login. YT really killed video sharing because they want more data… i like the chocolate covering of everything
    1. Privilege? Seriously? Tell us: Who grants that privilege to us serfs, then? Whose permission must we seek to have a bit of fun?
      If you feel so strongly about it, why are you wasting time writing comments here and worthlessly berating others for doing anything else, and why are you not getting out there and doing something about it instead of uselessly wringing your hands?
      Comments like that have no place here.
      Moderators please go ahead and have your way.
    1. Total right! I didn’t, i went to grab the double boiler and then it turned out to be full of soup. Then i ran out of prep time. So the chocolate was not as hard as i wanted but still dang good.
Leave a Reply to rikCancel reply
