A Mechanical Calculator For The Modern Age
There was a brief period through the 1960s into the 1970s when the last word in electronics was the calculator. New models sold for hundreds of dollars, and owning one made you very special indeed. Then the price of the integrated circuit at their heart fell to the point at which anyone could afford one, and a new generation of microcomputers stole their novelty for ever. But these machines were by no means the first calculators, and [What Will Makes] shows us in detail the workings of a mechanical calculator.
His machine is beautifully made with gears hand-cut from plywood, and follows a decimal design in which the rotation of a gear with ten teeth represents the numbers 0 to 9. We’re taken through the mechanical processes behind addition, subtraction, multiplication, and division, showing us such intricacies as the carry lever or a sliding display mechanism to implement a decimal equivalent of a bitwise shift multiplication.
We have to admit to be particularly impressed by the quality of the work, more so because these gears are hand made. To get such a complex assembly to work smoothly requires close attention to tolerance, easy with a laser cutter but difficult by hand. We heartily recommend watching the video, which we’ve placed below the break.
Meanwhile if you’d like more mechanical calculators, take a look at one of the final generation of commercial models.
16 thoughts on “A Mechanical Calculator For The Modern Age
  1. I have the remains of a friden computerized accountancy desk with pegboard programming and a IBM model C typewriter for input/output. internally the brains of the machine was a friden STW10 mechanical calculator, with every button needed activated by a solenoid and the output read back with decimal encoders. it must have been from the late 60’s and Friden didn’t like electronics at all, simple relais and mechanical calculators was all they had and used. unfortunately the machine was broken up for parts decades before i could get my hands on it.
  2. That is awesome .. and true dedication to a project. Impressed. Those guys that came up with the ‘first’ mechanical box back in time, as in ‘invented’, is mind blowing (at least to me). The inventor and the craftsmen to make it so. Really cool.
    Now, I suspect, one could just CAD your idea up. Fit the parts on screen, test in software, and then 3D print the parts and test results and iterate as mechanical problems are found. Probably make a much smaller, lighter box in the process.
    1. You put first and invented in quotes and I’m reminded of the antikythera machine; doubtless it was not the first of its kind, it is clearly too advanced in both design and technique. I wonder what the first one was. Most likely we’ll never know
  3. I’m very impressed by the craftmanship and some clever design features, particularly that it can do division. The only mechanical calculator I’ve seen in person didn’t do division, however the multiplication feature was fully automated.
    Since this is just a show piece, it doesn’t matter that wooden gears aren’t going to last a long time. One change I would make is adding a click-stop mechanism to the input sliders.
Leave a Reply to gregori128Cancel reply
