Selectively Magnetizing An Anti-Ferromagnet With Terahertz Laser
It’s a well-known fact that anti-ferromagnetic materials are called that way because they cannot be magnetized, not even in the presence of a very strong external magnetic field. The randomized spin state is also linked with any vibrations (phonons) of the material, ensuring that there’s a very strong resistance to perturbations. Even so, it might be possible to at least briefly magnetize small areas through the use of THz-range lasers, as they disrupt the phonon-spin balance sufficiently to cause a number of atoms to ‘flip’, resulting in a localized magnetic structure.
The research by [Baatyr Ilyas] and colleagues was published in Nature, describing the way the 4.8 THz pulses managed to achieve this feat in FePS3 anti-ferromagnetic material. The change in spin was verified afterwards using differently polarized laser pulses, confirming that the local structures remained intact for at least 2.5 milliseconds, confirming the concept of using an external pulse to induce phonon excitation. Additional details can be found in the supplemental information PDF for the (sadly paywalled with no ArXiv version) paper.
As promising as this sounds, the FePS3 sample had to be cooled to 118K and kept in a vacuum chamber. The brief magnetization also doesn’t offer any immediate applications, but as a proof of concept it succinctly demonstrates the possibility of using anti-ferromagnetic materials for magnetic storage. Major benefit if such storage can be made more permanent is that it might be more stable and less susceptible to outside influences than traditional magnetic storage. Whether it can be brought out of the PoC stage into at least a viable prototype remains to be seen.
9 thoughts on “Selectively Magnetizing An Anti-Ferromagnet With Terahertz Laser
  1. I wonder, if FePS3 were laminated onto a Bi-2223-type II superconductor tape doped with nanoparticles and maintained at its critical temperature, could this laser pulse both heat the Bi-2223 above its critical temperature and induce a sufficiently strong magnetic field, such that the field would persist long enough to allow the superconductor to cool back below its critical temperature, thereby enabling flux pinning to remain as an aftereffect? Maybe a preceding laser pulse of a different frequency would be better to achieve the heating effect?
    1. Fairly normal, yes. You’ll find some disciplines lean towards wavelength and others to frequency for defining lasers. Specifying in nm is definitely more common in optics papers andi think THz is more common in communications papers.
Leave a Reply to CMH62Cancel reply
