It’s simple enough to wire up an LED matrix and have it display some pre-programmed routines. What can be more fun is when the LEDs are actually interactive in some regard. [Giulio Pons] achieved this with his interactive LED box, which lets you play with the pixels via motion controls.
The build runs of a Wemos D1 mini, which is a devboard based around the ESP8266 microcontroller. [Giulio] hooked this up to a matrix of WS2812B addressable LEDs in two 32×8 panels, creating a total display of 512 RGB LEDs. The LEDs are driven with the aid of an Adafruit graphics library that lets the whole display be addressed via XY coordinates. For interactivity, [Giulio] added a MPU6050 3-axis gyroscope and accelerometer to the build. Meanwhile, power is via 18650 lithium-ion cells, with the classic old 7805 regulator stepping down their output to a safe voltage. Thanks to the motion sensing abilities of the MPU6050, [Giulio] was able to code animations where the LEDs emulate glowing balls rolling around on a plane.
It’s a simple build, but one that taught [Giulio] all kinds of useful skills—from working with microcontrollers to doing the maths for motion controls. There’s a lot you can do with LED matrixes if you put your mind to it, and if you just start experimenting, you’re almost certain to learn something. Video after the break.
Cool, but can it play Doom ?
Or at least Tetris ?
Adafruit has a pair of boards: the Matrix Portal M4 (ATSAMD51J19) and the newer Matrix Portal S3 (based on the ESP32-S3) with an accelerometer on board, and a guide showing a similar project at https://learn.adafruit.com/adafruit-matrixportal-m4/using-the-accelerometer.
Cool …
(here’s some interesting things to try as next steps)
Add mass. All dots, once free to move, appear to instantly jump to a fixed velocity. Consider simulating acceleration. Next, try simulating inelastic collisions or a bit of bouncing when dots hit each other and transfer their energy to each other.
Add a function to start a Game of Life simulation using whatever configuration the lighted dots are in when you stop moving the box for a few seconds. Moving it again restores the original configuration of dots.
