Back To Basics: Hacking On Key Matrixes
A lot of making goes on in this community these days, but sometimes you’ve just gotta do some old fashioned hacking. You might have grabbed an old Speak and Spell that you want to repurpose as an interface for a horrifyingly rude chatbot, or you’ve got a calculator that is going to become the passcode keypad for launching your DIY missiles. You want to work with the original hardware, but you need to figure out how to interface all the buttons yourself.
Thankfully, this is usually an easy job. The vast majority of buttons and keypads and keyboards are all implemented pretty much the same way. Once you know the basics of how to work with them, hooking them up is easy. It’s time to learn about key matrixes!
Wire ‘Em Up
A simple 3 x 3 matrix layout that allows six pins to read nine buttons. The buttons are organized into three rows and three columns. Credit: author
Imagine you have a piece of consumer hardware, like a desk phone or an old control panel or something. You’d like to hook up a microcontroller to read all the buttons. Only, there’s 10, or 20, or 100 buttons… and your microcontroller just doesn’t have that many I/O pins! If you’re only familiar with hooking up a couple of push buttons to a couple of pins on an Arduino with some pull-up resistors, this can feel like an overbearing limitation. However, thankfully—there is a better way!
Enter the key matrix. It’s a very simple way of hooking up more buttons to less I/O pins. Imagine, for example, a nine-digit keypad, arranged in a 3 x 3 square. Assign three pins for columns, and three pins for rows. Each button in the keypad is hooked up to one row pin and one column pin. You can then, for example, energize each row pin in turn with a high output on a microcontroller, and detect whether any of the column pins go high by setting them to inputs. Do this quickly enough, and you can detect the state of all nine buttons with just six pins. In fact, the technique is generalizable—for n pins, you can address (n/2)2 buttons. For six pins, that’s nine buttons.
In this diagram, each circle represents a button, which is connected to the pins whose lines intersect within. With this method, it’s possible to address many more buttons with the same amount of I/O pins as a regular row-column layout. Credit: author, inspired by work from Touchscreen1
You can even take it further, if you abandon the concept of a grid-like row-and-column layout. You can instead take six pins, for example, treating each one as its own “row.” You then place a button between it and every other pin, doing the same for each following pin in turn. You can then energize pin 1, while scanning pins 2 through six to see which buttons were pressed, and so on through the rest of the pins. This will net you a higher amount of buttons per pin—(n2-n)/2, in fact. For our six pin example, you could address 15 buttons this way.
When you expect multiple button presses at a time, you should add diodes into the button matrix to prevent current paths taking unexpected directions, and you might be lucky enough to find that your device already has them. There are even more advanced techniques, like Charlieplexing, that can address n2 – n switches, but you’re less likely to come across this in the wild except for pin-constrained LED circuits.
These techniques are commonly referred to as multiplexing, and you’ll find it in all sorts of places. Everything from TV remotes to desktop calculators use this sort of technique to address many buttons without requiring lots of individual I/O pins.
Sometimes you’ll find a piece of hardware with neat little test pads that link up with the rows and columns of the keypad matrix. This makes things easy! Credit: author
Once you’re aware of this, it generally becomes straightforward to open up any such piece of hardware and figure out how the buttons work. All you need to do is hunt down the traces that connect from button to button, and slowly map out how they’re all connected. Mapping out the board can be challenging, though, because designers don’t always make the traces easy to follow. While something like a keypad may be logically connected in a grid-type layout, for example, it might not actually look like that on the PCB. The traces might be going every which way, complicating your efforts to figure out what’s connected to what.
A multimeter set to continuity mode is a great tool for this work. It lets you tap around a PCB to figure out which side of each button is connected to which other buttons, allowing you to figure out how the matrix is laid out. For example, if you were working with a phone keypad, you might start by putting a multimeter lead on one of the contacts of the “1” button. You might then find that it’s connected to one side of the buttons for 3, 5, 9, and *. You can then probe the other side of each of those buttons to find out what they’re connected to as well. Put all this data into a spreadsheet, and you’ll eventually see which two pins you need to check to determine the status of any button on the keypad.
Generally, you’ll also find all the traces lead back to some main chip or connector, where you can easily solder on leads to hook up your own microcontroller to read all the buttons. It’s not always this easy—some boards will help you out with accessible test pads, while others will only provide tiny solder points for fine pitch connectors. In a worst case scenario, you might have to scrape solder resist off some traces so you can solder your wires in that way.
Once you’ve got a microcontroller hooked up to your button pads, the hard part is over. You just need to write some simple code to scan the key matrix and detect button presses. You can use a pre-baked library if you so desire, or you can do it yourself. Ultimately, a simple way is to just energize a row with an output I/O pin while setting all the column pins to inputs to see if any buttons are currently pressed, and stepping through the rows from there. You can get fancier about it if you like if things like latency or anti-ghosting are critical to you, but that’s a discussion for another time. With the high clock speeds of modern microcontrollers, it’s trivial to read even a large key matrix at a rapid pace.
Figuring out how to interface button pads on random hardware is a fun hacking skill to learn, and is accessible for beginners.
It’s worth noting that you might also have to cut some traces going to components of the original circuit, depending on what you’re hacking on. Oftentimes it’s not necessary, particularly if you’re unfussed what happens to any original circuitry on the board. For example, if you do intend to restore the item you’re hacking to original function, it might not be good to be probing the keypad with a 5  V microcontroller when the original hardware all ran at 3.3V. You might hurt the original chips on board if some voltage ends up where you didn’t intend it to go.
If you’ve ever dreamed of turning an air conditioner remote into a secret access panel for your home security system, or making your microwave into a cellular phone, these techniques will serve you well. Go forth, hunt down the matrix, and hack an appliance’s original user interface into the control panel of your dreams.
13 thoughts on “Back To Basics: Hacking On Key Matrixes”
  1. Did some keyboard reversing with a Brother PT-H110 label maker a little while ago, ended up scanning the bottom of the PCB and tracing things out in inkscape or gimp, forget which. Quite the tedious process!
  2. If you are going to put one or two diodes on each switch, you can just go with power on one side of the switch and a binary output for (2^n)-1 buttons. (all pins input, no output)
    6 pins, all inputs, 63 buttons. (63 buttons and no buttons = 64 possible states)
    Personally, I like having an extra button for the number zero button, this requires a few more diodesand an extra line , but gives you a debounce / interrupt input.
    5+1 lines give you 32 keys for the alphabet and interrupt/valic.
    1 line for an normally closed Ctrl key
    1 line for a shift key
    1 extra switch for a numeric key
    24 keys have 2 diodes, 6 keys have only one = 54 diodes
    and you have 7 bit ASCII encoded and an interrupt line in 8 in pins.
    of course this doesn’t help you hack the air conditioner….
    -G.
  3. For those who care, a lot of scientific calculators like this can be hacked without having to pop them open. All you need is a data cable and some spare time. But I’ve always wanted to repurpose one of these as a controller. I’ve tried them for audio purposes for fun and research – you generally have to solder on an op-amp of some sort just to amplify some really trash 1-bit sound, but it’s the principle of the thing.
  4. Haha oh yes I’m relatively new to all of this and it really did took some time to figure out how they manage to handle all the buttons, logic on LED controller that contains only 1 8pin IC (marked PRT100 H233, it’s confidential), battery, IR led, and 24 keys. Ultra cheap design, it’s really genius.. if interested in getting one it came with 3-4 eur e27 rgb bulb. It’s one of those that on first line has brightness up, down, black coloured off, red coloured on, second line R, G, B, W.. then 3×4 of colours and the 4th column is flash, strobe, smooth, mode. IC is soldered on back side, can repurpose those buttons optionally get a 3v cell holder as well: cut a trace join further (for buttons), solder and wire out cell holder contacts :-) For all sorts of cool mods, precision hacking it is good to get comfortable with soldering solderable ~0.2mm / 32 awg magnetic wire, after getting it routed out of the enclosure – taping with polyimide tape as a fixture for further soldering of whatever is preferred
  5. There are some LED matrix display ICs intended for segment displays that also use their segment pins to scan a key matrix, with I/O over I2C, which could be useful for projects with a pin-constrained microcontroller. TM1628A and TM1637 are both under $0.25 on LCSC, but they are 5V parts which expect at least 2V of headroom above the LED forward voltage.
