This Week In Security: Target Coinbase, Leaking Call Records, And Microsoft Hotpatching
We know a bit more about the GitHub Actions supply chain attack from last month. Palo Alto’s Unit 42 has been leading the charge on untangling this attack, and they’ve just released an update to their coverage. The conclusion is that Coinbase was the initial target of the attack, with the open source agentkit package first (unsuccessfully) attacked. This attack chain started with pull_request_target in the spotbugs/sonar-findbugs repository.
The pull_request_target hook is exceptionally useful in dealing with pull requests for a GitHub repository. The workflow here is that the project defines a set of Continuous Integration (CI) tests in the repository, and when someone opens a new Pull Request (PR), those CI tests run automatically. Now there’s an obvious potential problem, and Github thought of it and fixed it a long time ago. The GitHub Actions are defined right in the repository, and letting any pull request run arbitrary actions is a recipe for disaster. So GitHub always uses actions as they are defined in the repository itself, ignoring any incoming changes in the PR. So pull_request_target is safe now, right? Yes, with some really big caveats.
The simplest security problem is that many projects have build scripts in the repository, and those are not considered part of GitHub Actions by GitHub. So include malicious code in such a build script, make it a PR that runs automatically, and you have access to internal elements like organization and repository secrets and access tokens. The most effective mitigation against this is to require approval before running workflows on incoming PRs.
So back to the story. The spotbugs/sonar-findbugs repository had this vulnerability, and an attacker used it to export secrets from a GitHub Actions run. One of those secrets happened to be a Personal Access Token (PAT) belonging to a spotbugs maintainer. That PAT was used to invite a throwaway account, [jurkaofavak], into the main spotbugs repository. Two minutes after being added, the [jurkaofavak] account created a new branch in spotbugs/spotbugs, and deleted it about a second later. This branch triggered yet another malicious CI run, now with arbitrary Github Actions access rather than just access through a build script. This run leaked yet another Personal Access Token, belonging to a maintainer that worked on both the spotbugs and reviewdog projects.
That token had access to create and edit tags in reviewdog/action-setup, a GitHub Action that runs as a dependency for multiple other actions. The attacker created a fork of this repository, added malicious code, and then overwrote the v1 git tag to point to this malicious code. The tj-actions/changed-files ran a CI flow that made use of the malicious reviewdog/action-setup fork, leaking a GitHub token with write permission to tj-actions/changed-files.
The tag override trick does a lot of heavy lifting in this story, and that’s what was used on tj-actions/changed-files too. Another malicious fork, and a specific tag was overridden to point there. The tag chosen was one used in a Coinbase repository. Specifically coinbase/agentkit used the newly malicious tag in one of its workflows. A Coinbase maintainer discovered this, and deleted the targeted workflow, putting an end to the Coinbase-specific attack. At this point, the attacker opted to burn the pilfered access, and pushed malicious code to every tj-actions/changed-files tag. The idea apparently being that there would likely be some interesting secrets that were leaked. It’s also possible this was intended to hide Coinbase as the primary target. Regardless, that’s the widespread attack we’ve already covered, and now you know the rest of the story.
ZendTo: No CVE, No Problem?
ZendTo is a nifty Open Source, web-based file sharing platform. It’s been around for a while, and the release notes from a 2021 release makes reference to a “security fix” with no additional details given. That caught the attention of [Jay] from Project Black. It sounds like a potential vulnerability, but it seems like no CVE was ever assigned, and no further details were given.
Here’s the issue: ZendTo has an anonymous file upload feature on by default. This has a security feature built in, in the form of scanning the uploaded file with ClamAV in a temporary location, before moving the file to its long term storage directory. Part of this process includes the ever lovely exec("/bin/chmod go+r " . $ccfilelist); line. PHP has some footguns to be aware of, and calling exec() with any user-provider input is one of them. And of course, the user-provided tmp_name value is used to construct the $ccfilelist string. Set tmp_name to 1;command, and you’ve got code execution.
There is another outstanding issue, where legacy md5 passwords that happen to begin with 0e will be interpreted as a number in scientific notation. PHP handles some type comparisons a bit weirdly. These scientific notation values all evaluate as 0. Using any password that also evaluates to one of these special “scientific” md5 hashes, and the comparison collapses to 0 == 0. So one out of every 256 users have a trivially bypassed password — if their account was still using a md5 password hash.
So here we have a pair of serious vulnerabilities, though one has limited exposure, with neither being fully disclosed nor given CVEs. What’s the result of this lack of transparency? Old, vulnerable installs of ZendTo are still on the Internet. Without a CVE, there’s much less pressure to update. No CVE doesn’t necessarily mean no vulnerabilities.
Researcher [Evan Connelly] was looking into the Verizon Call Filter iOS app, and found it to be using an interesting web service. The callLogRetrieval endpoint allows a user to look up call logs for their own Verizon number. Authorization is done using JSON Web Tokens (JWT), which included a “sub” field, indicating the phone number the token was authorized to fetch. The request itself also has a field to indicate the number being queried. This particular endpoint uses a JWT for authorization, but returns the information requested in the query field — without comparing the two values. Yes, any customer that could obtain a valid JWT could query the call records of virtually any other Verizon number. While this is particularly bad, Verizon acknowledged it quickly, and rolled a fix out in less than a month.
When Parameterized Queries Aren’t
What’s the single most powerful tool to prevent SQL injection attacks? Easy: Parameterized queries. Write the SQL query ahead of time, the library converts it into native database code, and only then are the user-generated values plugged in. In theory that means those values can never be understood as part of the SQL logic. While there are ways this can still go wrong, the basic approach is sound. But what if a language, like Nim, had a parameterization option that didn’t actually do parameterized queries?
Yes, Nim’s db_postgres module provides the facility to run code like getRow(sql"SELECT username FROM users WHERE username=?;", "user"), which is intended to protect against SQL injection. But, under the hood, it really is just doing string replacement with character escaping, like replacing null characters with \\0. Now consider PostreSQL’s standard_conforming_strings setting, which among other things, removes the backslash as a special character. But if that setting is disabled, the backslash can be used to escape quotes. Nim doesn’t know anything about that behavior. This combination of not-actually-parameterized parameterization, and lack of awareness of the standard_conforming_strings behavior, means that ./poc '\' ' OR user_id=1; --' is once again a potential SQL injection. Whoops.
Oracle: Oh, That Oracle Cloud!
We finally have a bit more insight into what’s going on at Oracle. You probably remember that the company has continually denied a breach into Oracle Cloud. It seems this is a bit of verbal sleight-of-hand, as Oracle has renamed part of their cloud offering to Oracle Cloud Classic. The remaining, current generation service is the Oracle Cloud. Oracle Cloud Classic has suffered the breach, not technically Oracle Cloud.
It’s not clear that this is really all there is to the story, though, as more data is getting released by the attacker, including video of a web meeting from 2019. Oracle has started reaching out to customers and confirmed the breach, though apparently strictly avoiding putting anything in writing.
Microsoft Joins the Hotpatch Game
Enterprise Linux distros have long had support for various forms of live-patching. We even interviewed TuxCare about this feature for FLOSS Weekly a few weeks ago. It seems that Microsoft finally wants in on the fun. Windows 11 Enterprise has in-memory security patching starting with the 24H2 update. This support is strictly for machines with an Enterprise or certain Education Microsoft subscriptions. The Hotpatches will be available for 8 of the 12 monthly security patches, with an enforced quarterly update via traditional updates and a reboot.
Bits and Bytes
Researchers at GreyNoise have noted an uptick in IPs scanning for Palo Alto device login pages for several days in March. The scanning had as many as 20,000 unique IPs hunting for these login interfaces, which suggests a botnet has been tasked with finding these devices. It’s very possible that a threat actor has found a new vulnerability in Palo Alto devices, and is preparing to launch an attack.
And finally, a pair of posts from ZDI caught our attention this week. The first is a dive into how Binary Ninja’s static code analysis can find potential use-after-free vulnerabilities. The second is all about building an electric car simulator, that can actually plug into real electric vehicle charging stations, and actually fool the charger into believing a car is attached. How is this problem approached safely, given the high voltages and amperages involved? Very carefully.
2 thoughts on “This Week In Security: Target Coinbase, Leaking Call Records, And Microsoft Hotpatching”
  1. “The Hotpatches will be available for 8 of the 12 monthly security patches, with an enforced quarterly update via traditional updates and a reboot.” . That would be nice(r) for work. Every week we reboot at least once, sometimes more. Yuck… All my Linux systems just hum along at home and only reboot when I want them to reboot and/or what updates I want to apply. So much nicer that it is on my schedule … not some outside entity forcing updates and mucking around systems… If I don’t want updates for a year, that is my call. My systems.
