Celebrating 30 Years Of Windows 95 At VCF
It’s been 30 years since Windows 95 launched. [Ms-Dos5] and [Commodore Z] are celebrating with an epic exhibit at Vintage Computer Festival East 2025. They had no fewer than nine computers — all period-correct machines running versions of Windows 95. The pictures don’t do it justice, so if you are near Wall, NJ, on Sunday, April 5, 2025, definitely go check out this and the rest of the exhibits at VCF.
An exhibit like this isn’t thrown together overnight.Β  [Commodore Z] and [Ms-Dos5] worked for months to assemble the right mix of desktops, laptops, and peripherals to showcase Windows 95. Many of the computers are networked as well – which was no easy task.
One particular Thinkpad 760e required pliers and force to remove a stuck PCMCIA modem card. After a struggle that was ultimately destructive to the card, the pair determined it was stuck due to a sticker that had effectively glued the card into the laptop. As the sticker finally gave up, the card popped itself out of the laptop.
Hardware isn’t the only story of this Windows 95 exhibit. An operating system is software, after all. The team has plenty of software running. Some highlights are Kid Pix, MS-paint, LEGO Island, Full Throttle, Duke Nukem 3D, Word 97, and Space Cadet Pinball, which came with the Plus! expansion pack. There is a huge array of original boxes for Windows 95 software. It’s a nostalgia trip to see software in boxes, especially in all those bright 90’s colors.
The various versions of Windows 95 are also represented. [Ms-Dos5] and [Commodore Z] are running all major versions from Chicago beta 73g to Windows 95 C / OSR2.5.
If you’re old enough to remember it, the Windows 95 launch event was a big deal. Windows 3.0 series was five years old at that point. Millions of people owned PC compatible computers and were ready for something new and flashy, and Windows 95 delivered. Thanks to [Commodore Z] and [Ms-Dos5] keeping this bit of internet history alive.
78 thoughts on “Celebrating 30 Years Of Windows 95 At VCF
  1. Bright 90’s colours and GUI designs that did not rely on having a gazzilion inch ultra super quad HD resolution monitor to scale the interface down to less than 25% of the screen area.
    1. One of the high points of my mid-90s nostalgia was seeing Windows running on giant 30+ inch Trinitron televisions and CRT projectors even though the resolution was still just 640×480 or 800×600 (or MAYBE fuzzy 1024×768 interlaced)
      (also apologies I accidentally reported this comment)
  2. Hammerhead drum machine by Bram Bos, ReBirth 338 by Propellerheads, ModPlug Tracker (now known as OpenMPT). I made a lot of music on Windows 95, I could record to wave file but on a 2GB HD I couldnt keep the files for long. I would play Slamscape and Death Drome while my parents shouted at me to turn down the sound lol. Peak 90’s experience, DOS preceded this and having a full OS gave me a feeling of power that later versions of Windows didnt deliver on.
    1. Windows ’95 was not a full OS. It was a shell around DOS, just like Windows 3.1. A better shell, no doubt about that. With Windows 98se, it started to become more like a full OS. But it really never was.
      Windows NT on the other hand WAS a full OS. But for some reason, Windows NT only came to the masses with Windows XP. Who’se conception was propelled by the failure that was called “Windows ME”.
      1. A “shell”.. Yes, but not just. Windows 3.0 described itself as “Graphical Environment” on the box, which I think is fair.
        And that can be more than just a shell, like DOS Shell.
        What many laymen don’t realize is that Windows has characteristics of an operating system:
        – its own executable format (NE, New Executable)
        – its own printer spooling
        – its own device drivers (VXD, DRV)
        – its own memory managment (uses himem.sys or DPMI for access only)
        – its own scheduler (co-operative multitasking, message qeue)
        – its own 386 virtual machine monitor (like EMM386)
        – partial emulation of MS-DOS API, int21h for Windows 3 applications (FastDisk etc)
        Windows for Workgroups even has a protected-mode network stack and a HDD cache
        If both the native HDD Cache and HDD driver (aka FastDisk) is activated, WfW nolonger calls DOS most of the time.
        It’s then running on its own, basically.
        It sort of qualifies as a Network Operating System, thus.
        Windows 9x has the Virtual Machine Monitor (VMM) as its heart.
        It’s thus structly not running “on DOS”, but under DOS.
        During start-up, Windows 9x moves DOS into a separate V86 machine.
        Windows 9x is basically an hyper visor, a virtual machine monitor.
        It needs DOS, but has it under control. Thanks to V86 mode.
        1. Also notable environments among others were GEM and GEOS, I think.
          They had their own applications, too, but I’m not sure if they had their own executable format, too.
          You know, their own version of “exe” files, with special headers.
          DESQView/X could run Windows 3.1 in a window, but also ported/re-compiled X11 applications.
          Normal DESQView had its DESQView API and support for running special accessories, but I’m not exactly if it was that special. πŸ€·β€β™‚οΈ
        2. EMM386.exe was a memory manager not virtual machine. EMM = extended memory manager. It was itself a memory resident software. Computers had conventional memory of 640KB then some could extend ram using modules but needed a memory manager to be utilized. It would be loaded into conventional memory if I remember right. If you configured everything right you can load it into the Upper Memory Block (UMB) using himem.sys.
          1. “EMM386.exe was a memory manager not virtual machine.”
            Sure it was! It used V86/80386 MMU, like QEMM and the others did! πŸ™‚
            That’s why some DOS fans insist in running DOS in pure Real-Mode, after all!
            EMM386 intercepted access to real hardware, even.
            The A20 lime was being virtualized (emulated, rather), for example.
            It also supported DPMI.
            There are even APIs that are being used by utilities such as SoftMPU, TEMU (Tandy 3-Voice Emulator), VSB (Virtual SBlaster) or SBEMU.
            For I/0 trapping purposes.
            EMM386 was like a little operating system, running at Ring 0.
            It was a V86 Virtual Machine Monitor. Or V86 hypervisor, maybe, in modern language.
            But that’s not mentioned on Wikipedia, sadly. Its EMM386 wiki is way too superficial.
            This article at os2museum is more detailed, I think.
            The author knows much more than me, I must admit.
            https://www.os2museum.com/wp/the-importance-of-emm386/
  3. It was a sad day. Windows NT was a flop when it was marketed as the next desktop, OS/2 was showing what a real pre-emptive multitasking OS can do on PC hardware(albeit tough to install on some) and Chicago was thrown together from bits of NT, parts of HP NewWave and mostly DOS can with millions in marketing and tech rag marking dollars spent.
    Anyone who had used UNIX at the universities or OS/2 knew Windows 95 was the computer industry’s version of a McDonalds hamburger. It looked the part and filled a space but it was not even close to being good unless you didn’t know better.
    1. Windows 95 delivered a simple but effective solution to the average user. It had a friendly user environment, setting up new hardware and software was a breeze (compared to alternatives at the time.) Just like the McDonalds hamburger, it was cheap, hastily put together and not very good compared to other options. None of those reasons ever stopped people coming back again and again for more, however. There’s good and then there’s “good”.
      1. What stops people from going back is experiencing something better. This is likely why Microsoft went to such great lengths stopping alternatives from getting preloaded on PCs. BTW, Windows 95 came out at a time when not only were hardware vendors putting their own desktop interfaces on Windows 3.x like Comaq’s Rolladex desktop and HPs New Wave desktop, this little thing called the Internet was available. It turned out that IBM knew the network was important so all the software to use the Internet was bundled with OS/2. The dial up TCP/IP stack and both client and server applications all were available to users out of the box. The TCP/IP stack was an add on from a 3rd party for Win3.x. Windows 95 locked hardware vendors out of changing the desktop and pretty much turned software development at the hardware vendors into driver testing and development departments.
        It was “good” only to those who knew no better and were prevented from knowing any better. The hardware vendors would have solved any installation and driver issues but were prevented from doing that.
          Now count the huge numbers of people who did experience the alternatives, and still came back.
          Which was an excellent choice, since the hardware vendors had no idea of UI/UX design and were constantly trying to break the paradigm.
          They would have introduced n + 1 ways to break the system even further, and sneak in “bugs” to trip their competitors while they were at it.
        2. IBM did see the opportunity to own the IP stack on Windows as well – there was a lovely product called the IBM Internet Connection for Windows, which we in IBMs OEM division would take, and customise for certain customers. That way they could ship a custom CD with their paper or magazine, for users to install the ICW on their Windows computer which would automatically prompt the user to sign up for their favourite local ISP. We did some work with a number of Nordic customers like newspapers and so on, that sold a sign-up to Telia and made the local daily newspaper web site the home page. Good business while it lasted ;-)
        3. These “locks” as you call it provide structure. Without something to provide a framework every “solved problem” would have been done with tweaks and hacks, and likely have broken again, and quickly.
          Microsoft (as much as it is currently acting like a rhesus monkey addicted to tiktok), provided structure so that hardware would inter-operate, and remain backwards compatible as much as possible.
          95B is definitely a milestone. Anybody else remember restarting explorer regularly to get the system back from a lock up?
        4. Dude, no one is claiming 95 was a “serious” OS. But it was fun to use and made the PC vastly easier for home users. It gamed well, was backwards compatible with DOS and was flexible enough to get folks on the early internet.
          It was the perfect OS for the time and machines of the era. That’s why folks still like it.
      2. “setting up new hardware and software was a breeze (compared to alternatives at the time.)”
        Only if you didn’t know any better. Just out of curiosity: what are those alternatives that you are making a reference to?
        1. You’re missing the entire point. Not “knowing any better” is the EXACT thing that made 95 a big deal. The 90s saw the boom of home users who weren’t tech enthusiasts or electrical engineers or some other professional field. It was just the average Joe who heard that he can track his finances or use this thing called “AOL” to talk to his friend or look up stuff.
          You think someone like that is going to survive an OS/2 setup or, god forbid, a Unix based environment with one of a handful of different user environments? Win95 came out of the box ready to go with everything the homegamer needs to be introduced to the world of computing. As a young person myself in the 90s my first experience with a computer was 3.11 and when I saw 95 for the first time I was blown away with how much “better” everything was.
          Looking back, it was the cleaner UI, no distinctions between a “file” and a program, they all shared the same visual space. It even had tools to help you get set on-line with wizards that would usually work so long as you had a modem and a phone line.
          Context here is key. 95 was never meant for us power users. It was for everyone else.
          1. “As a young person myself in the 90s my first experience with a computer was 3.11 and when I saw 95 for the first time I was blown away with how much β€œbetter” everything was.”
            Funny how different people are. I was young, too, but had a different taste.
            Back in 1995, I always prefered the existing “2D look” of Windows 3.x and NT 3.x.
            I also liked the colorful Windows 2.03 that we still had at home in the floppy box in the drawer. It had that 80s vibe.
            Windows 95 GUI looked ugly to me, it was the “tomb stone” look.
            Because the grey made look everything made out of concrete.
            Reminded me of soulless city landscapes with skyscrappers.
            Windows 3.1 had a friendly face, by contrast. More innocent, still.
            Years later, I realized that the Windows 3.x 2D look also was being shared by OS/2 1.2, 1.3 and 2.0 (beta).
            And that the GUI elements were similar to Motif/CDE in Unix world.
            You know, Unix graphics workstations. SGI, HP etc.
            The kind of stuff on which Donkey Kong Country was rendered, for example.
            The color white (background etc) of Windows 3.x was also being used by GEM on PC and Atari ST, the DOS Shell, Macintosh’s System (Mac OS) etc.
            That’s why it looked sympathic to me, I guess.
            It was a reminiscence of the fading 16-Bit era, which I liked.
            The Windows 95 grey rather reminded me of the Playstation, which was the platform of soulless 3D games to me.
            I didn’t enjoy the move away from cheerful, hand-crafted 2D sprite art games to soulless, rendered 3D games with a low polygon count.
            The Macintosh adopted the tomb stone look with Mac OS 8, I think. That so-called Platinum look..
            OS/Warp was grey, too, but it at least was good under the hood.
            Anyway, I don’t mean to ruin everyone’s memories here.
            I’m just saying that there were users with other opinions, too. Like me.
            I know there are people who actually loved Windows 95 and the Playstation. And that’s okay. I guess..
            After all, the colorschemes in OSes could be changed.
            There were replacement cases for the PSone, too.
            So players could swap the ugly grey Playstation chassis to something nice.
          2. “Context here is key. 95 was never meant for us power users. It was for everyone else.”
            Absolutely. 100% agree.
            It also was useful to migrate existing DOS hardware and software.
            What’s positive about Windows 9x was that Windows 3.1x drivers and DOS drivers could be used.
            That way, it was possible to link DOS-based networks with Windows-based networks, for example.
            Or simply keep using DOS networking software.
            That had drawbacks like impaired performance and being limited to 8.3 filenames,
            but resources such as printers shared via the old network software could still be used.
            Windows 9x also allowed direct hardware access,
            which was nice for hardware development in general.
            In an electronics lab, security is of secondary importance, after all.
            Since It’s an isolated, lonely PC anyway it’s more important to be able to talk to port addresses and parallel port.
            That way, ISA prototype cards and small series equipment can be used easily without a need for writing a highly complex VXD/DRV driver.
            PC interfaces for Playstation and other game console equipment used parallel port, too.
            On DOS (and OS/2) or Windows 3.x/9x they could be accessed, thus.
            Windows NT required something like PortTalk library to allow port access, but it wasn’t available in the 90s yet.
          3. “After all, the colorschemes in OSes could be changed.”
            Exactly. I always hated the inverse color schemes that emerged in the ’90s, so I used the Windows color-scheme editor to simply make a charcoal-based scheme that looked exactly like today’s “dark” schemes. Back then, you could define a scheme at the system level, and all properly-coded applications would inherit it.
            When the general public finally realized that inverse color schemes sucked, Microsoft had REMOVED the scheme editor from Windows. I mean… WTF? And the vaunted Apple GUI NEVER had user-definable color schemes.
            So now everyone had to run around and hurriedly slap a hard-coded “dark” theme together at every level. OSes, applications, Web sites… what a mess. This problem was solved more than 30 years ago by every GUI except Apple’s… and then the solution was abandoned.
            And measles is making a comeback. People aren’t getting smarter.
    2. Windows NT wasn’t marketed as “the next desktop.” It was marketed as the business OS. It was secure and did networking natively. Unfortunately, it couldn’t be both secure and support DOS (and therefore Win95) hardware drivers. In 1995 Microsoft was not yet in a position to tell all of its customers that every single camera, scanner, sound card, and machine peripheral they ever acquired was now suddenly obsolete all at the same time. They still had actual competition who would make use of that against them. By the time they sunseted 98SE and forced everyone to XP, they did have that market clout and the manufacturers saw it as an opportunity to sell new hardware rather than a burden to redo support for what was already out there. The world’s e-waste landfills burped in contentment, and life went on.
      1. “Unfortunately, it couldn’t be both secure and support DOS (and therefore Win95) hardware drivers.”
        Right. That’s were OS/2 Warp 4 was an alternative.
        It was a real, preemptive multitasking OS like Windows NT but with a better DOS VM and limited direct hardware access.
        Its virtual Windows 3.1 also could use a few device drivers.
        The supplied Sound Blaster drivers in Win-OS/2 come to mind.
        Like NT, it could run DOS and Windows in separate VMs.
        OS/2 Warp 4.x could have been a strong Windows NT 4 competitor in late 90s if it ran ordinary Win32 applications, too.
        I mean, it kinda did via Win31+Win32s, but compatibility was limited to well-written Win32 applications.
        If only ODIN compatibility layer was available and mature enough in late 90s..
        (That’s right, OS/2 Warp can run things like IrfanView or Winamp via ODIN!)
        1. WTF are you talking about?
          OS/2 could not support devices that required DOS drivers, at all.
          95 ran much much better is there were no DOS mode drivers.
          ME got it’s reputation trying to support DOS mode drivers, stank to heaven.
          OS/2’s death was it’s limited hardware support.
          It was ‘fine’, if you bought a machine built for it.
          Was nightmare, it you just tried to install it on random machine and had bad luck.
          Wouldn’t tell you it was f’ed, incompatible.
          Would try to operate in hardware compatibility mode, like Windows install, but much much worse.
          1. “OS/2’s death was it’s limited hardware support.”
            Was it? Windows NT had similar issues, hadn’t it?
            However, OS/2 had been advertised to end-users/comsumer hardware.
            Maybe that was IBM’s mistake.
            On PCs capable of running Windows NT, such as i486 workstations, OS/2 2.11 or Warp didn’t run worse than NT I would say.
          2. No, it depended on the chipset.
            Only one device had to lack a native OS/2 driver and you were out of luck/running in VGA compatibility mode/not networking or just random crashing.
            NT3.51 also lacked drivers, but (key point) install would tell you.
            Not try to plod on in some nightmare half working mode.
            NT4 driver support was good.
            That was ME using a common driver model, forcing the issue.
          3. A TSR was never a driver.
            It was an awful hack program that lived in a single DOS shell, hanging off interrupts and generally mucking about with BIOS calls and hardware.
            I’m surprised the kids haven’t reinvented TSRs, but in JS.
          4. About DOS drivers vs OS/2.
            In the 80s/early 90s, there had been special EMMs that ran in OS/2 DOS compatibility box (aka penalty box).
            They allowed DOS programs to access physical memory boards (ISA cards) providing Expanded Memory (EMS).
            We’re talking about 16-Bit OS/2 here, even, not just ordinary OS/2 as we know it.
            No matter how we look at it, OS/2 was more tolerant, more forgiving than NT.
            OS/2 VDMs had offered much more flexibility here.
          5. “NT4 driver support was good.”
            Yeah, in the US, maybe. Where everyone had a Dell computer with same basic hardware. ;)
            Over the pig pond, err, big pond, hardware was still more diverse at the time.
            We still had our own hardware manufacturers, a left over from the 1980s.
            They slowly declined but weren’t completely gone yet.
            Existing designs from the 80s could be made up-to-date by using a 386SX processor
            in new production runs or by selling 386 upgrade cards.
            But of course, plain ISA motherboards that complied to PC/AT standard did run fine on all OSes of the time, no question.
            Including OS/2 and NT. And Nixul.. Lunix.. err, Linux.
            But once hardware got a bit more obscure, non-standard, then both OS/2 and NT had struggled.
            That’s were Windows 9x had shined.:
            It could run on about anything, since it could run on anything already made for DOS or Windows 3.1x before.
            By late 90s it could even emulate Sound Blaster cards via VXDs (used by makers of PCI sound cards).
          6. “A TSR was never a driver. It was an awful hack program that lived in a single DOS shell”
            I don’t think TSR was even as clever as that. At the time a TSR is called, there’s no DOS shell running. It was just an INT (INT 27h) that terminated the current application, adding DX (<32kB) to the starting address of any future application.
    3. Well for that matter windows 95 version A had major issues that had to be addressed in version B. There wasn’t a ton of places using OS/2, it never really took off like that. It started to then it lost momentum. Sad as it had a ton of potential.
  4. There are still 1.0-4.0 PWS unpatched RCE floating around the internet
    Imagine running a modern fuzzer against OSR 2.5 browser options and SMB 1.0 with all patches applied(if you can even collect all the patches since nobody made AIO till XP)
    1. “We invite you to participate in the Hackaday comment section of each article in a way that is kind and respectful to everyone. Comments should never be hateful, vulgar, obscene, abusive, incoherent, or off-topic.”
      We want the comments to be on-topic and/or constructive, and we do what we can to keep them civil. Unfortunately, that means deleting those comments which are not.
      If you have a specific issue, please reach out to us: editor@hackaday.com.
      1. It was on-topic.. Somehow it was politically unaligned even though there was nothing political in the comment; I made a comment on personal web server 1.0-4.0 and 95 compatible browsers and it wasn’t allowed to be even posted let alone deleted..
        Political correctness is insane here; if you’re going to do it at least have it work right..
        1. Smart money’s on user error. I myself hate all minorities and want to blow up the world, yet this comment got posted.
          (No, of course I don’t.)
          1. I’ve been here over a decade and never had a comment “queue”‘d.. Even if so, it emphasizes the point that everything else I’m posting immediately goes through and is light years more argumentized and critical..
            I can’t imagine what the regex or word list looks like That PWS requires human labor.. I’m going to go out on a limb and say that’s some acronym for something to do with American politics..
            We got to keep America/The-Internet safe from such things.. Just say no to standardized testing am I right?
      1. Windows 10 had at least 3 major incompatible revisions, bit of a moving target that. When it started life it was Windows 7 with Metro Apps and Internet Explorer. In the middle it adopted new sleep states and hardware, and now it runs chromium and is basically Win11 in all but name.
        1. In looks and feel, Windows 95 was more like Mac OS 8. Or System 7.5, at least.
          System 6 was like Windows 3.0 or 3.0 Multimedia Edition.
          System 7 was like Windows 3.1 (TrueType, QuickTime etc).
        2. “It didn’t run it’s file system or network stack in a virtualized Z-80 or 6502!”
          No, Windows 9x rather did run its file system or network stack in a virtualized 386.
          The DOS part was running in an V86 instance and needed for backwards compatibility.
          Such as for accessing file system, if say a DOS disk cache software was run.
          Or for accessing network, if a DOS network sofware was being used.
          The DOS part also was being used if a DOS CD-ROM drive driver was being used.
          Windows 9x had its own version of MSCDEX built-in (CDFS.sys).
  5. Windows 95 made one thing a bit easier – it drew a line under support for the 286. The one reason that OS/2 saw the light of day, and wasn’t displaced by AIX was that AIX could only run on 386 hardware (and IBM’s RISC engines, of course). Some in the management layers in IBM Boca decided that the 286 had lots of runway still. Others were far less convinced, including the guys from Austin who came to Boca many times to try to convince them not to bother writing a true multitasking OS from scratch, when they already had one.
    1. “Windows 95 made one thing a bit easier – it drew a line under support for the 286.”
      Hi, yes, it did. But so did OS/2 2.x, Warp 3 and Windows for Workgroups before.
      And the latter supported the 286 merely as a client, at best.
      The many commercial DOS memory managers such as
      QEMM, 386MAX, CEMM and EMM386 did make users wanting to switch to 386/486 PCs soon enough.
      But that being said, I don’t think the 80286 was bad at all. It’s underrated, rather.
      Windows 3.1 and OS/2 1.3 demonstrated how capable the 286 was.
      And how stable segmented memory was.
      Too bad Windows 3.1 didn’t implement virtual memory for 286 Protected-Mode, though.
      On bright side, however, it had multimedia support (sound cards, video).
      Last but not least, 16-Bit development didn’t stop with Windows 95, but rather 98SE.
      16-Bit development tools such as Visual Basic 3 or Borland Pascal 7 were still being used a lot in mid-90s.
      Newly written 16-Bit Windows applications detected Windows 95 as version “3.95” and could use advanced features not found on Windows 3.1x.
  6. … just plug it in. It’s gonna say, ‘Hey! I see you’ve plugged in a new device’, and it’s gonna load in the appropriate drivers. You’ll notice that this scanner… wow!
  7. It was a big deal … at the time. But now Linux is way forward for the foreseeable future. Not looking back at Windoze (except maybe for nostalgia purposes) at this address.
    1. Right. And this saddens me. Really, it does. It’s so backwards/stuck.
      Back in the 80s and 90s, Unix had a good reputation and was considered a professional, commercial platform.
      There had been Minix, too, for the rest of us. Or Xenix.
      In early 90s, graphics workstation running on Solaris, HP/UX and other Unices were respectable platforms.
      We normal users didn’t own them, but we respected them.
      Reading about Unix always had been a joy.
      It was an inspiration to learn about the world of the “big iron”.
      Then Linux came, “a new star was born” so to say. And with it, so came the teenage thugs.
      Now, *nix software nolonger was considered commercial grade software, but freaky half-finished stuff made by kids, then so-called “basement dwellers”.
      That’s at least what ordinary people had started to think about, if they had heard GNU/GPL/FOSS/X11.
      They also made the false connection Linux equals Unix (Linux=Unix).
      Which in hindsight did hurt real Unix or BSD a lot.
      *nix nolonger had been associated with mainframes, professionals or university students, but anti-social youngsters from the slums programming garbage.
      Open source and the never to be finished software projects were an exact opposite to commercial Unix world, in short.
      While the situation nolonger is as bad as it used to be in the 90s, Linux still remains being “freaky”.
      It has a cult following, and its followers worship it.
      Whenever an alternative operating system emerges,
      someone says “don’t bother with it, use Linux!”
      Linux here! Linux there! Linux everywhere! πŸ™„ sigh.
    2. I forgot to mention, I was an Linux user myself by late 90s/early 2000s.
      I had bought a boxed copy of SuSe Linux 6.
      Installation wasn’t for the fainthearted, not even for DOS fans among of us.
      The installation scripts were cryptic, the documentation worded badly.
      A far cry from commercial Unix software that used normal, human language.
      In a nutshell, Linux distros were a permanent construction site.
      There was no standard paket manager, no online-help as there was in MS-DOS 6. Just to name two issues.
      If you compared how polished MS-DOS world was by 1990 alreeady, it was a huge step backwards.
      On DOS, you had installers that took you by the hand, while simultanously getting into technical detail.
      Think of Norton Utilities or PC-Tools. Or graphical WinBIOS firmware.
      You had TUIs (text-mode user interfaces) that used soft-font feature of EGA/VGA.
      That means TUIs that used custom text characters that looked like icons (close button, folder icon, mouse cursor).
      Like MS-DOS Shell had featured in graphical text-mode.
      To normal users, not the C/C++ diehards, Linux was a really bad experience.
      They had high expectations, they had believed in the propaganda of Linux of the time. Then followed disillusionment.
      Linux worked, sorta, if you were willing to make sacrifices.
      If you were willing to assemble your PC with Linux compatibility in mind, if you were willing to compile your kernal with modifactions.
      If you were willing to use SCSI scanners and CD-ROM drives rather than parallel or USB models.
      If you made sure that there was no powerouttage happening (UPS recommended), otherwise filesystem corruption.
      If you had been willing to run X11 via VESA VBE (unaccelerated) in absence of native drivers.
      Unless you had a supported graphics chip from ~1993. S3 Trio32/64 or ATI MACH64 etc.
      Again, I lived through these times. To an DOS/Win3.1 user Linux wasn’t the upgrade that had been promissed.
      Yes, it had preemptive multitasking, but so had OS/2 Warp, which also had accelerated Super VGA and GRADD drivers.
      IBM had licensed drivers from Scitech in Warp 3 or 4, I think.
      If you were Linux, you had to spend a lot of time settings up.
      Which was okay if tinkering with computers was your hobby.
      But if not, then you had to be prepared for the suffering of your life.
      The hard disk partitioning alone was pure stress.
      You had to make sure that multiple partitions were being reserved, most inportantly swap partition.
      You had to make sure that the boot loader was set correctly, that partitions had the correct ID and that the partition type was correct.
      You had to make sure the boot partition was active etc.
      Compared to this, FDISK, FORMAT and SYS on DOS was a kids’ play.
      On DOS, any flavor of DOS, the FDISK program would provide you hints and ask questions about the important stuff.
      And if you missed a step, you could go back and proceed it.
      Not so on Linux. You had to know exactly what to do, know it inside out. In right order. Otherwise, you had to start over. From scratch.
      Configuration of X11 (XFree86) was similar.
      Not only you had to find the correct configuration file, but also the one meant for your user account.
      You needed the permission to edit/save the file, of course.
      If you were doing things on root permission level,
      it could be that the config file nolonger could be accessed on user level once you needed it.
      Speaking of editing, there was no such thing as MS-DOS editor (TUI based).
      You had to use something compatable to EDLIN from DOS 2.0 era.
      Something similar to nano, but even more cryptic I remember.
      If only Midnight Commander was available on boot/installer medium!
      These are just some points to give people an idea how Linux alienated existing users at the time.
      It caused pain that still hurts, 25 years later.
      While commercial Unix maybe had similar utilities and appearance,
      it was a different level of quality.
      Commercial Unix had proper documentation in human readable form, comparable to printed manuals of MS-DOS or Mac OS.
      It had documentation written in whole sentences, in short. With examples being mentioned. With pictures.
      Documentation that was still valid at the time of release and a bit after it, too.
      Linux is a fast moving target, distributions change things over night for no obvious reasons, harming printed media, confusing users.
      Linux, of course, was (is) so different because it was the product of computer freaks (hey, Linux was considered to be called “Freakix”).
      The product of C/C++ coders in particular.
      And writing good manuals wasn’t exactly part of their skill set
      (SuSe guys tried to compensate for this with their printed manuals).
      The missing comments in C/C++ source code are a good indicator here.
      You see, Linux was written by computer freaks for other computer freaks, in short.
      Anyway, I don’t mean to criticise Linux too much here, it did a good job at dismantling itself already.
      So good that people like me still remember its flaws 25 years later, a quarter of a century.
      – To be fair, though, no one was being forced to use it at the time;
      unlike nowadays maybe where it is being basically enforced as that one, holy universal solution to all our computing needs.
      What’s also not to be forgotten is that Linux fans had never experienced a real operating system before, obviously.
      Otherwise, if those Linux coders/fans had ever had put hands on commercial Unix system, then the user experience wouldn’t have been that bad and hostile as it was (is).
      PS: Some people may not like what I wrote, I understand this.
      But from my point of view, I can’t deny what I had experienced, either.
      Originally, I had an unbiased opinion to Linux, I’ve bought my own copy of SuSe Linux after all.
      I was excited about trying something new, there was no hate whatsoever.
      But then I saw all these flaws and I knew it’s not for me. Or vice versa.
      Linux apparently had a different philosophy or paradigm than what a friend of DOS, CP/M, Basic, asssmbly language or Turbo Pascal was used to be.
      Or what a home computer user, an electronic hobbyist was used to be.
      Everything was C centric beyond the mere source code, even.
      The filesystem structure was similar complicated to directory structure of a C compiler.
      Admittedly, Unix was similar at heart but it also had a focus on binary compatibility and supporting other languages and paradigms.
      Supporting various commercial software in short.
      But still, despite all these flaws, I still gave Linux a second chance.
      And a third one. A fourth one. A fifth one. A sixt one..
      I’ve even recommended others giving Knoppix (incl. AFU-Knoppix) and Ubuntu a try.
      Yet, Linux still doesn’t deliver what it had promissed in the 90s.:
      Being a stable, quick operating system that runs your favorite software.
      Example: In the mid-late 90s, a Pentium 90 with 24 MB of RAM and a 2GB HDD was barely enough to run Linux properly. It was a resource hog.
      Windows 98SE ran normally on same computer.
      Now in 2025, Linux doesn’t run on an much faster Pentium III with 512 MB RAM and 20GB HDD. It’s still a resource hog, not a lightweight OS.
      Meanwhile, Windows 98SE still runs normally on same computer. ;)
      Sure, this looks like joke, but the point is that Windows 98SE still can run modern day applications (Win32).
      You still can run latest IrfanView, for example. Or play DirectX games.
      DirectX 9c is being supported, KernelEx project adds Windows Vista/7 applications compatibilty.
      There’s VBE9x and SoftGPU for modern graphics cards (Linux used to fall back VBE too).
      A Linux from 2000 can’t do that. It’s been obsolete in no time.
      Yet people still claim that Linux is the way to go, that is the future.
      Just to whom? I’d be disappointed if nothing better would emerge eventually.
      Because Linux is becoming just another monopoly, like Windows used to be.
      That makes the integration of Linux into Windows (WSL) even more ironic, I think.
      Linux isn’t becoming a free alternative, it’s becoming the monopoly.
      It’s assimilating everything, like the Borg would do. Best regards,
        1. I don’t know. I’ve written that during night time, when I became pensive.
          Guess I got a bit too philosophical here, sorry about that.
          But still, Linux wasn’t all rainbows and sunshine.
          Since the news was about Windows 95 and the 90s, I thought I should write down these “memoirs”.
    3. PS: I think that QNX is/was an positive example of a lightweight unixoide system.
      Versions released in the late 90s ran quickly on a 386/486 PC, if memory serves.
      There also was a version that hosted an Amiga emulator, which had very high performance! AmigaXL/QNX 6.1, I think.
      So there’s hope for Unix, still. If done properly, it can work out well.
  8. First computer, Pentium 120, 14.4k modem, printer, mouse, keyboard, 14″CRT monitor and the biggest HDD At the time 300MB all with Windows 95 .. at low price if $5229 … but once you heard win95 start … all worth it 😁
  9. Windows 95’s most important strength was its user interface design language, as codified by that book you can see peaking out behind the leftmost exhibitor: The Windows Interface Guidelines for Software Design.
    The standards it enumerated for the sake of commonality and ease of use are what made 95 stand apart from its predecessors (both older Windows and rival OSs), making it an easy to understand experience. That didn’t happen by accident, those choices were well-researched, tested, and properly studied. The Start menu and the Taskbar helped out considerably to that end. You also had the revamped titlebar and menu system of Explorer which was then echoed in all other programs (where applicable), featuring the minimize/maximize/close iconography. Resizing individual windows and boxes manually was easy and obvious, scrollbars all followed a common design language.
    So much of that was owed to the 3D design concept of individual windows where light was sourced from the same place in the top left corner, making it easy to identify the borders of any UI element and know where something began and ended (now undone by flat design). I mentioned scroll bars before, but that’s one element that modern mobile design has truly decimated in the name of saving screen real estate, forcing users to find the magic pixel to scroll. If you’ve got 4K of screen, that’s difficult to find, but not on 95! MS got it right the first time, and the slow erosion of this common element on desktop interfaces in the name of saving space (on ever-larger resolution displays) is a design trend that universally detracts from the UX of the modern world.
    One of the best parts of 95 was the reconfigurability of the UI, allowing regular folks the ability to customize the color scheme, layout, and general organization of the elements present in their menus and desktop. This was a major step up for a consumer OS, because one could reconfigure and customize the style of their UX without having to be a programmer or know how to edit config files; it was all in the menus! Freedom. Freedom to do it in some really goofy, and personalized ways if they so chose because it was their computer. Like “sort by penis” (if anyone remembers that video).
    Yeah, plug-and-play was in its infancy, but man it was a major step forward. We take that for granted now, especially when drivers can be sourced and downloaded automatically by the OS from the internet, but obviously such an automated system has not always existed, and the roots are right here in 95.
    I genuinely believe modern UI designers have alot they can learn from studying the formal design language rules laid out by the Windows of old, and 95 is a prime example they should start with. The progression within 95 on display here captures that pretty well, I hope there are higher quality photos to look at everything.
Leave a Reply to Nicholas SargeantCancel reply
