Amazing Oscilloscope Demo Scores The Win At Revision 2025
Classic demos from the demoscene are all about showing off one’s technical prowess, with a common side order of a slick banging soundtrack. That’s precisely what [BUS ERROR Collective] members [DJ_Level_3] and [Marv1994] delivered with their prize-winning Primer demo this week.
This demo is a grand example of so-called “oscilloscope music”—where two channels of audio are used to control an oscilloscope in X-Y mode. The sounds played determine the graphics on the screen, as we’ve explored previously.
The real magic is when you create very cool sounds that also draw very cool graphics on the oscilloscope. The Primer demo achieves this goal perfectly. Indeed, it’s intended as a “primer” on the very artform itself, starting out with some simple waveforms and quickly spiraling into a graphical wonderland of spinning shapes and morphing patterns, all to a sweet electronic soundtrack. It was created with a range of tools, including Osci-Render and apparently Ableton 11, and the recording performed on a gorgeous BK Precision Model 2120 oscilloscope in a nice shade of green.
If you think this demo is fully sick, you’re not alone. It took out first place in the Wild category at the Revision 2025 demo party, as well as the Crowd Favorite award. High praise indeed.
We love a good bit of demoscene magic around these parts.
Thanks to [STrRedWolf] for the tip!
34 thoughts on “Amazing Oscilloscope Demo Scores The Win At Revision 2025
    1. Responding to the intensity suggestion…
      In college (many many) years ago, I was a lab assistant in an Industrial Engineering department. To support an human factors Engineering Design class, the hardware guy built a switch box with a cutout fitting the display of a Tektronix 525 Oscope we placed behind it. We defocused the beam to a diameter of a few millimeters to prevent burn.
      We had an ADC and the switch box allowed us to detect swhich of the buttons was pressed.
      I implemented a bit of software (Dec PDP-8/L, two DACs) to draw a 5×8 character by parking the beam for a few milliseconds at the position of each lit dot. We had a variable scan rate (imagine “1” vs “8”).
      It would have been an interesting experiment to implement a variable-park-time setting to challenge the experimental subject by changing the presented character’s brightness.
      It was a glorious project, allowing an 18-year-old student to do something “real” in school.
    2. While this is possible, it requires three digital to analog converters, so it wouldn’t work with a standard sound card. I think where you see variations in intensity in the video, this is effected with changes in beam scan speed, which is the proportional to slew rate, or the first derivative of the changing voltage. Slower rise and fall rates -> slower beam motion -> brighter appearance.
  1. So how does this work? Is it the signal that is visualised using the oscilloscope and music added later, or is the music the signal? Hoe does someone do this? Can I learn this? Amazing. Respect.
    1. Music is the signal, which is the amazing part. Music is split into two channels, one controlling the x axis and the other the y axis.
      The concept can be understood from the beginning of the demo – first a single sine wave is played on the y axis channel; this shows as a vertical line with the size corresponding to the amplitude (volume) of the wave. Then the x axis starts a sine wave which spreads the y axis signal out horizontaly, with different harmonics changing how that looks. Then everything gets magical and the creators show off some true virtuoso artistry
      It’s achieved ultimately by piping two audio channels into a ‘scope
      Can’t help with learning how to do this (these guys are clearly extremely talented individuals, and have spent a lot of time getting good with this technique), but DJ Level 3 is in the comments for this article so maybe he could help :)
  2. Has someone finally broken Jerobeam Fenderson’s code, or is he in the background here somewhere? I couldn’t find any link between Jerobeam and Bus Error Collective or DJ Level 3. Anyway, the most important part of oscilloscope music is the music, and the music here is good.
    1. I’ve downloaded the flac, took the dust out of my old analog scope and split a RCA cable to connect it to my stereo to have the full experience.
      It looks glorious! Its a masterpiece. Congratulations to the creator
  3. That was sick. Good music, cool ashetic, and the visual and audio glitchiness adds to the whole effect. That being said, my gut says the audio and video would be so far apart in the frequency domain that they’re practically seperate signals. I may be mistaken about that.
      1. But how much is stuff that is basically inaudible. Like some of the transitions I couldn’t detect the sounds changing, like the names. Either way though it’s still impressive and absolutely most of it was providing a visual representation of what you could hear the music doing.
  4. Lots of sound in the rear channels with a basic surround setup! I wonder weather this would show well through the deflection coils on a x-y vector game display? Quite impressive.
    1. You can make this work for any sample rate, but the complexity of what you can draw without visible flickering decreases with lower sample rates or sound cards that filter out the high frequencies.
Leave a Reply to BrightBlueJimCancel reply
