Sometimes you find a commercial product that is almost, but not exactly perfect for your needs. Your choices become: hack together a DIY replacement, or hack the commercial product to do what you need. [Daniel] chose door number two when he realized his Yamaha MusicCast smart speaker was perfect for his particular use case, except for its tragic lack of line out. A little surgery and a Digital-to-Analog Converter (DAC) breakout board solved that problem.
[Daniel] first went diving into the datasheet of the Yamaha amplifier chip inside of the speaker, before realizing it did too much DSP for his taste. He did learn that the chip was getting i2s signals from the speaker’s wifi module. That’s a lucky break, since i2s is an open, well-known protocol. [Daniel] had an Adafruit DAC; he only needed to get the i2s signals from the smart speaker’s board to his breakout. That proved to be an adventure, but we’ll let [Daniel] tell the tale on his blog.
After a quick bit of OpenSCAD and 3D printing, the DAC was firmly mounted in its new home. Now [Daniel] has the exact audio-streaming-solution he wanted: Yamaha’s MusicCast, with line out to his own hi-fi.
[Daniel] and hackaday go way back: we featured his robot lawnmower in 2013. It’s great to see he’s still hacking. If you’d rather see what’s behind door number one, this roll-your-own smart speaker may whet your appetite.
an adafruit DAC ? what Fruit is it ?
In his write up, he says it’s the PCM5102 I2S DAC breakout.
I have fixed the capitalization issue as well, thanks.
man, yamaha and built-in speakers&s….
i’ve got a yamaha keyboard (e-piano) that is pretty good all around but its built in amplifier functions as a compressor, it compresses the dynamic range of what you play. so the quiet notes are almost as loud as the loud notes. it’s one of the “digital piano” line, not one of the kids’ toys or portable synths, so it’s a real disappointment. even running it through a $1 garage sale guitar amp with a lot of hiss and distortion improves the artistic expression of the instrument.
a real frustrating and apparently continuing lapse in yamaha’s engineering. they get so much right and then put the worst amplifier for the purpose? like, the responsiveness of the action on this piano is impressive, and they went through all of that work to then run it through a compressor in the last stage…wtf
Sounds like (ha) a bean counter wanted to save pennies. They’ve probably got engineers crying about this
make a very concise write up of the issue, with data in appendices
include solution (ie what they should have done, ideally with an idea of price difference)
send to both CEO of Yamaha and of that department
A reasonable chance that a query from the top gets a change for future models
