A Simple Tip For Gluing Those LED Filaments
[Boylei] shows that those little LED filament strips make great freeze-frame blaster shots in a space battle diorama. That’s neat and all, but what we really want to highlight is a simple tip [Boylei] shares about working with these filament strips: how to glue them.
Glue doesn’t stick to LED filament strips, so put on a small piece of heat-shrink and glue to that instead.
The silicone (or silicone-like) coating on these LED filament strips means glue simply doesn’t stick. To work around this, [Boylei] puts a piece of clear heat shrink around the filament, and glues to that instead. If you want a visual, you can see him demonstrate at 6:11. It’s a simple and effective tip that’s certainly worth keeping in mind, especially since filament strips invite so many project ideas.
When LED filament strips first hit the hobbyist market they were attractive, but required high operating voltages. Nowadays they are not only cheaper, but work at battery-level voltages and come in a variety of colors.
These filaments have only gotten easier to work with over the years. Just remember to be gentle about bending them, and as [Boylei] demonstrates, a little piece of clear shrink tubing is all it takes to provide a versatile glue anchor. So if you had a project idea involving them that didn’t quite work out in the past, maybe it’s time to give it another go?
6 thoughts on “A Simple Tip For Gluing Those LED Filaments
  1. A handy tip for my next cosplay project. This would probably work for EL wire and over thin rubberized elements.
  2. Those filament LEDs seem to be commonly used in this kinds of builds.
    I follow a YouTube channel (https://youtube.com/@outworldatelier) that also used them in a battle scene, but also for an explosion with cotton balls.
    There’s even an explanation about the resistors that are used, a more challenging part for model builders it seems.
  3. Oh yes!
    I have this half a death star on my wall and at some point i was trying to figure out how to get a lazer beam coming out from it and this is the answer!
    That (topic) diorama looks amazing.
Leave a Reply to Frank OntreeCancel reply
