DIY Navigation System Floats This Boat
navdesk
[Tom] has taken a DIY approach to smart sailing with a Raspberry Pi as the back end to the navigation desk on his catamaran, the SeaHorse. Tucked away neatly in a waterproof box with a silicone gasket, he keeps the single board computer safe from circuit-destroying salt water. Keeping a board sealed up so tightly also means that it can get a little too warm. Because of this he under-clocks the CPU so that it generates less heat. This also has the added benefit of saving on power which is always good when you aren’t connected to the grid for long stretches of time.
A pair of obsolescent phones and a repurposed laptop screen provide display surfaces for his navdesk. With these screens he has weather forecasts, maps, GPS, depth, speed over ground — all the data from all the onboard instruments a sailor could want to stream through a boat’s WiFi network — at his fingertips.
There’s much to be done still. Among other things, he’s added a software defined radio to the Pi to integrate radio monitoring into the system, and he’s started experimenting with reprogramming a buoy transmitter, originally designed for tracking fishing nets, so that it can transmit his boat’s location, speed and heading instead.
The software that ties much of this system together is the open source navigational platform OpenCPN which, with its support for third-party plugins, looks like a great choice for experimenting with new gadgets like fishing net buoy transmitters.
For more nautical computing fun check out this open source shipboard computer, and this data-harvesting, Arduino-driven buoy.
Thanks to [Andrew Sheldon] for floating this one our way.
10 thoughts on “DIY Navigation System Floats This Boat
  1. Hi this is Tom from this video.
    Thanks hackday for highlighting my raspberry pi powered sailboat project.
    I am going to be posting regular updates on my Youtube channel “Sailing Seahorse” please subscribe which would really help me keep posting.
    Upcoming projects:
    M5Dial boat info system
    Espruino bangleJS open source watch boat internments
    A new solar power and battery system controlled by home assistant
    remote Lora Meshtastic anchor alarm
    Thanks
    Tom
    1. Indeed, given how powerful they are it’s surprising we don’t see them used in place of Pi’s or even Arduinos more often – I guess the barrier to getting something working on them without the obsolete OS complaining is a bit high and IO is minimal.
  2. Tidy setup! I like the repurposed mobile phones. Other complementary Open Source projects to check out are Signal K and Openplotter.
    And yes, those net buoys are not legal. Even if you flout official certification, these are transmit only devices and will ignore the protocol for allocation of time slots, which is fundamental to AIS. This leads to transmitters talking over each other, disrupting communication in busy areas. Maiana is/was an Open Source projects that does it right.
Leave a Reply to AdrianCancel reply
