Keeping retrocomputers going can be tricky enough, but when you’re talking retro laptops, the battery packs add an extra challenge. While one could simply live without the battery, that’s not going to give you the full retro experience. Replacement batteries are long out of stock, so what can one do? Well, one can check out this excellent tutorial by [lazd] on rebuilding an iBook G3 Clamshell battery.
Even if you don’t have this particular laptop, the general process is likely to be similar for PC laptops of similar vintage. (Which we still can’t believe is a whole quarter-century ago.) Luckily for retrocomputer enthusiasts, even Apple used standard 18650 cells in those bygone, halcyon days when computers were allowed to be more than a few atoms thick. They do need to be unprotected, flat-top cells, but that’s easy enough to source.
So it’s really a matter of carefully prying apart the casing (apparently it needs to be Apple-branded; aftermarket cases can’t survive being opened), removing the old batteries, and welding nickel tabs onto the new cells in the proper configuration. One thing that surprised us is that, apparently, Apple did not go in for balancing in those days — so make sure your cells are all in perfect condition and all equally charged before you start, or things won’t end nicely.
Assuming you can pull it off (and your battery pack’s control chip has lasted the 300 moons since its manufacture), you’ll get a not-insignificant 5-hour battery run out of what’s sure to be the cutest clamshell computer at the cafe.
If you are repairing an iBook, while you’re at it, why not upgrade the RAM? You might even be able to fix the screen if it’s succumbing to the sadly-too-common vinegar syndrome.
Probably wise to hack a balance connection into the battery, even in the form of probe holes in the shell.
Or fit a small active balancing board inside?
Christ, unbalanced? That’s horrifying.
Luckily it will be used a grand total of less than an hour anyway, so the risk is minimal
If that board doesn’t do balancing, why are all the cells connected to it?
There’s a datasheet for the “gas gauge” IC on the board at the end of the article. Looks like it keeps track of the charge level, battery age, and things like that. The lack of balancing seemed really weird to me, too.
And that BQ2040 doesn’y monitor individual cell voltages: only the total battery voltage.
So the question remains: why are the intermediate cell voltages connected to that PCB, if not for balancing?
In the forum link on the bottom of the article there seems to be mention of a Mitsumi MM1414 battery protection IC, it can monitor multiple cell voltages in a 3S/4S pack for over/under voltage.
Tried to search for a schematic to see if any balancing is present but can’t seem to find anything.
I’m in the middle of a G3 iBook conversion and one of the hardest parts so far has been sourcing a battery. These are insanely expensive, and I don’t even want to use the onboard battery management.
If you aren’t using the onboard battery management, why not just put your own batteries where the original went? The Clamshell should have a lid on the battery bay, so no one would ever know what you were doing in there. (Not that I’d advise just stuffing it with pouch cells, but… you could.)
Also, once you’re far enough along with that project to want to show it off, please let us know! It sounds like something we’d write about.
I haven’t figured out where I’m going to put the batteries yet. I’m using the RP500, which expects to be plugged into a wall. The battery board in the original iBook also holds the button for the trackpad and the lid switch for sleeping, so the board is going to stick around either way (Probably. I don’t think I want to make a new board… but who knows)
The project is still pretty early in the process, but the saga is captured here: https://aaroneiche.com/projects/pibook/
I had this iBook G3 laptop when I was a teenager. My parents spent an arm and a leg.
To replace the tiny stock hard disk had to dismount the whole thing, luckily no glue, just dozens of screws.
It was slow, and after 6 months it was replaced by iBook G4 running MacOS X. Really frustrating :D
I had one, too. The stock RAM (32 MB ?) was barely good enough for Mac OS 9.2, I think.
No wonder, the system was made with Mac OS 8.5 in mind or something.
Upgrading it to a few hundred MBs of RAM made it run OS X Tiger, even.
But indeed, it wasn’t among the fastest. With enough RAM, it at least was no slug/snail anymore, though.
Btw, the The iBookGuy used to have some fine ibook repair/upgrade videos on YT.
They’re still worth watching, I think. Installing an SSD or CF card as HDD replacement might be worth a try, too. Their access time is much lower.
reminds me of my ibook g4…when i finally retired it, i looked back on the money i spent on it over the years, mostly repairs…and the one thing i regretted was i bought the RAM upgrade just a year before i retired it. it would have cost twice as much but i wish i’d done that the first day!
compare to now… i want a laptop with 2GB of RAM but my $150 laptop has 8GB. what a waste :)
I’ve heard some sad news that certain battery circuit boards intentionally self destruct once it detects bad cells, so even if you welded in new cells the board would be disabled. I’m not sure how true it is or how common but people online have warned about it.
Yes, many of them have a fuse with a heating element built in so the battery management chip can blow it on command. Even if you bypass the fuse, the battery management chip will be locked out.
I would not recommend rebuilding a lithium battery pack for a computer without charge balancing. That’s just a fire waiting to happen. It would be much safer to modify the computer to run from a USB PD power bank.
Hell, I’d be elated to find a Pelican or Otter Box style container designed to perfectly fit 18650 or 21700 batteries.
I’ve torn down supposedly legit aftermarket notebook batteries to find scary dirt floor hut hack jobs. No thanks to any rebuilt batteries, I’ve already experienced waking up to a burning house. For old Macs that throttle down when battery is missing or unhealthy, it would be great to have a non-hazardous battery simulator to tell the system it is ok to run at full load, maybe with supercaps to handle peak loads and momentary disconnects. Ideal for those one uses rarely and more stationarily than portably.
Nope. The cutest clamshell at the cafe would be a late model Zaurus.
I briefly hoped the article was about one of those but they had removable batteries no hack required.
Isoamyl acetate can be used to open these kind of plastic, just tape the parts you don’t want stained, pour the isoamyl with using an small tip needle syringe and wait a few minutes. it will open effortlessly.
